I am trying to run SSdlite_mobilenet_v2_cocoo on jetson nano. I was able to run ssd_inception_v2_coco(2017), ssd_mobilenet_v1_coco and ssd_mobilenet_v2_coco successfully following https://github.com/taka-wang/trt_example repo. But when I am trying to convert .pb file of ssdlite_mobilenet_v2_cocoo modell to tmp.uff and tmp.bin
this is the error:
python3: nmsPlugin.cpp:54: virtual nvinfer1::Dims nvinfer1::plugin::DetectionOutput::getOutputDimensions(int, const nvinfer1::Dims*, int): Assertion `nbInputDims == 3’ failed.
Aborted (core dumped)", this error is coming…
This is file of ssdlite confuguration:
import graphsurgeon as gs
path = ‘frozen_inference_graph.pb’
TRTbin = ‘tmp.bin’
output_name = [‘NMS’]
dims = [3,300,300]
layout = 7
def add_plugin(graph):
all_assert_nodes = graph.find_nodes_by_op(“Assert”)
graph.remove(all_assert_nodes, remove_exclusive_dependencies=True)
all_identity_nodes = graph.find_nodes_by_op("Identity")
graph.forward_inputs(all_identity_nodes)
Input = gs.create_plugin_node(
name="Input",
op="Placeholder",
shape=[1, 3, 300, 300]
PriorBox = gs.create_plugin_node(
name="GridAnchor",
op="GridAnchor_TRT",
minSize=0.2,
maxSize=0.95,
aspectRatios=[1.0, 2.0, 0.5, 3.0, 0.33],
variance=[0.1,0.1,0.2,0.2],
featureMapShapes=[19, 10, 5, 3, 2, 1],
numLayers=6
NMS = gs.create_plugin_node(
name="NMS",
op="NMS_TRT",
shareLocation=1,
varianceEncodedInTarget=0,
backgroundLabelId=0,
confidenceThreshold=1e-8,
nmsThreshold=0.6,
topK=100,
keepTopK=100,
numClasses=91,
inputOrder=[1, 2, 0], # its mine
confSigmoid=1,
isNormalized=1
concat_priorbox = gs.create_node(
"concat_priorbox",
op="ConcatV2",
axis=2
concat_box_loc = gs.create_plugin_node(
"concat_box_loc",
op="FlattenConcat_TRT",
concat_box_conf = gs.create_plugin_node(
"concat_box_conf",
namespace_plugin_map = {
"MultipleGridAnchorGenerator": PriorBox,
"Postprocessor": NMS,
"Preprocessor": Input,
"ToFloat": Input,
"image_tensor": Input,
"Concatenate": concat_priorbox,
"concat": concat_box_loc,
"concat_1": concat_box_conf
graph.collapse_namespaces(namespace_plugin_map)
graph.remove(graph.graph_outputs, remove_exclusive_dependencies=False)
graph.find_nodes_by_op("NMS_TRT")[0].input.remove("Input")
return graph
