Is there a version of the container for the voice demo:
docker pull nvcr.io/nvidia/jetson-voice:r32.4.2
that runs on l4t 4.3?
If I run the current one on my jetson agx xavier I get this:
docker run --gpus=all -it --rm --network host nvcr.io/nvidia/jetson-voice:r32.4.2 trtserver --model-control-mode=none --model-repository=models/repository/jasper-asr-streaming-vad/
I0922 14:47:49.755758 1 server.cc:115] Initializing TensorRT Inference Server
I0922 14:47:49.977182 1 server_status.cc:55] New status tracking for model 'ctc-decoder-cpu-trt-vad-streaming'
I0922 14:47:49.977410 1 server_status.cc:55] New status tracking for model 'feature-extractor-trt-vad-streaming'
I0922 14:47:49.977550 1 server_status.cc:55] New status tracking for model 'jasper-asr-trt-ensemble-vad-streaming'
I0922 14:47:49.977697 1 server_status.cc:55] New status tracking for model 'jasper-trt-decoder-streaming'
I0922 14:47:49.977785 1 server_status.cc:55] New status tracking for model 'jasper-trt-encoder-streaming'
I0922 14:47:49.977856 1 server_status.cc:55] New status tracking for model 'voice-activity-detector-trt-ctc-streaming'
I0922 14:47:49.978288 1 model_repository_manager.cc:675] loading: ctc-decoder-cpu-trt-vad-streaming:1
I0922 14:47:49.978979 1 model_repository_manager.cc:675] loading: feature-extractor-trt-vad-streaming:1
I0922 14:47:49.979573 1 model_repository_manager.cc:675] loading: jasper-trt-decoder-streaming:1
I0922 14:47:49.980316 1 custom_backend.cc:202] Creating instance ctc-decoder-cpu-trt-vad-streaming_0_0_cpu on CPU using libctcdecoder-cpu.so
I0922 14:47:49.980380 1 model_repository_manager.cc:675] loading: jasper-trt-encoder-streaming:1
I0922 14:47:49.980730 1 custom_backend.cc:205] Creating instance feature-extractor-trt-vad-streaming_0_gpu0 on GPU 0 (7.2) using libfeature-extractor.so
I0922 14:47:49.980840 1 model_repository_manager.cc:675] loading: voice-activity-detector-trt-ctc-streaming:1
I0922 14:47:49.982730 1 custom_backend.cc:205] Creating instance voice-activity-detector-trt-ctc-streaming_0_gpu0 on GPU 0 (7.2) using libvoice-activity-detector.so
I0922 14:47:50.031355 1 model_repository_manager.cc:829] successfully loaded 'voice-activity-detector-trt-ctc-streaming' version 1
E0922 14:47:54.824862 1 logging.cc:43] coreReadArchive.cpp (38) - Serialization Error in verifyHeader: 0 (Version tag does not match)
E0922 14:47:54.825820 1 logging.cc:43] INVALID_STATE: std::exception
E0922 14:47:54.825948 1 logging.cc:43] INVALID_CONFIG: Deserialize the cuda engine failed.
E0922 14:47:54.826204 1 model_repository_manager.cc:832] failed to load 'jasper-trt-decoder-streaming' version 1: Internal: unable to create TensorRT engine
E0922 14:47:54.826684 1 logging.cc:43] coreReadArchive.cpp (38) - Serialization Error in verifyHeader: 0 (Version tag does not match)
E0922 14:47:54.827467 1 logging.cc:43] INVALID_STATE: std::exception
E0922 14:47:54.828057 1 logging.cc:43] INVALID_CONFIG: Deserialize the cuda engine failed.
E0922 14:47:54.829108 1 model_repository_manager.cc:832] failed to load 'jasper-trt-encoder-streaming' version 1: Internal: unable to create TensorRT engine
I0922 14:47:58.020849 1 model_repository_manager.cc:829] successfully loaded 'feature-extractor-trt-vad-streaming' version 1
Would be good to have this for the latest l4t package:
head -n 1 /etc/nv_tegra_release
# R32 (release), REVISION: 4.3, GCID: 21589087, BOARD: t186ref, EABI: aarch64, DATE: Fri Jun 26 04:34:27 UTC 2020
