tegra194-audio-p3668.dtsi (7.3 KB)
tegra194-p3668-all-p3509-0000.dts (1.1 KB)
我们在35.1上适配alc5639,以上两个dtsi文件为修改的内容,刷入系统之后查看到如下结果:
,然后插上耳机,测试并没有发出声音。麻烦帮我们检查一下在哪里出的错误?谢谢!
Please read through following links for issue you are facing
Below link lists possible issue and their resolution
Below link guides on how to integrate a new codec on 40 pin gpio expansion header
Below link is to overall audio setup and development guide
https://docs.nvidia.com/jetson/archives/r34.1/DeveloperGuide/text/SD/Communications/AudioSetupAndDevelopment.html
您好!
这是我们开机打印的日志信息:
dmesg.txt (80.0 KB)
我们适配的rt5639还是没有出声,请您提供一些意见!谢谢!
First, ensure pinmux is set for relevant I2S and aud mclk. Guide for pinmux setting is available at Jetson Module Adaptation and Bring-Up: Jetson Xavier NX Series — Jetson Linux<br/>Developer Guide 34.1 documentation
Second, the dts override seems to be wrong instead use below as reference. Recompile kernel dtb and flash and check if the codec/card are being registered
i2c@3160000 {
rt5640: rt5640.8-001c@1c {
compatible = "realtek,rt5640";
reg = <0x1c>;
clocks = <&bpmp TEGRA234_CLK_AUD_MCLK>;
clock-names = "mclk";
realtek,dmic1-data-pin = <0>; /* RT5659_DMIC1_NULL */
realtek,dmic2-data-pin = <0>; /* RT5659_DMIC2_NULL */
realtek,jack-detect-source = <7>;
/* Codec IRQ output */
interrupt-parent = <&tegra_main_gpio>;
interrupts = <TEGRA234_MAIN_GPIO(AC, 5) GPIO_ACTIVE_HIGH>;
#sound-dai-cells = <1>;
sound-name-prefix = "CVB-RT";
status = "okay";
sound {
nvidia-audio-card,widgets =
"Headphone", "CVB-RT Headphone Jack",
"Microphone", "CVB-RT Mic Jack",
"Speaker", "CVB-RT Int Spk",
"Microphone", "CVB-RT Int Mic";
nvidia-audio-card,routing =
"CVB-RT Headphone Jack", "CVB-RT HPOL",
"CVB-RT Headphone Jack", "CVB-RT HPOR",
"CVB-RT IN1P", "CVB-RT Mic Jack",
"CVB-RT IN2P", "CVB-RT Mic Jack",
"CVB-RT Int Spk", "CVB-RT SPOLP",
"CVB-RT Int Spk", "CVB-RT SPORP",
"CVB-RT DMIC1", "CVB-RT Int Mic",
"CVB-RT DMIC2", "CVB-RT Int Mic";
nvidia-audio-card,mclk-fs = <256>;
&i2s5_to_codec {
link-name = "rt5640-playback";
codec {
sound-dai = <&rt5640 0>;
prefix = "CVB-RT";
