I2S0 pinmux configuration :
Device tree :
sound {
nvidia-audio-card,mclk-fs = <0x100>;
nvidia-audio-card,routing = "CVB-RT Headphone Jack\0CVB-RT HPOL\0CVB-RT Headphone Jack\0CVB-RT HPOR\0CVB-RT IN1P\0CVB-RT Mic Jack\0CVB-RT IN2P\0CVB-RT Mic Jack\0CVB-RT Int Spk\0CVB-RT SPOLP\0CVB-RT Int Spk\0CVB-RT SPORP> nvidia-audio-card,widgets = “Headphone\0CVB-RT Headphone Jack\0Microphone\0CVB-RT Mic Jack\0Speaker\0CVB-RT Int Spk\0Microphone\0CVB-RT Int Mic”;
iommus = <0x05 0x02>;
iommu-resv-regions = <0x00 0x00 0x00 0x40000000 0x00 0x60000000 0xffffffff 0xffffffff>;
status = “okay”;
compatible = “nvidia,tegra186-ape”;
nvidia-audio-card,name = “NVIDIA Jetson Orin NX APE”;
clocks = <0x02 0x5d 0x02 0x68 0x02 0x07>;
clock-names = “pll_a\0pll_a_out0\0extern1”;
assigned-clocks = <0x02 0x68 0x02 0x07>;
assigned-clock-parents = <0x02 0x5d 0x02 0x68>;
phandle = <0x323>;
after I use below commands :
$ sudo fdtoverlay -i kernel_tegra234-p3767-0000-p3768-0000-a0.dtb -o kernel_tegra234-p3767-0000-p3768-0000-a0.dtb tegra234-p3737-audio-codec-rt5640.dtbo
then modified rt5640 node from i2c@31e0000 to i2c@3160000<
$ sudo i2cdetect -y -r 3160000.i2c
$ lsmod | grep rt5640
audio path :
amixer -c APE cset name=“CVB-RT OUT MIXL DAC L1 Switch” on
amixer -c APE cset name=“CVB-RT OUT MIXR DAC R1 Switch” on
amixer -c APE cset name=“CVB-RT HPO MIX HPVOL Switch” on
amixer -c APE cset name=“CVB-RT HP Channel Switch” on,on
amixer -c APE cset name=“CVB-RT HP Playback Volume” 5,5
when I use aplay .wav, there are no sound output from Headphone.
how can I do ?
