Hello good people,
Is there a version of this API written in C (not C++)? If it is, do You have any examples of encoders/decoders written in C?
Thank You for Your help!
Hello good people,
The functions is implemented in classes so it is in C++. For programming in C, please check the samples:
/usr/src/jetson_multimedia_api/samples/unittest_samples
By default the samples are built with g++ but you should be able to modify Makefile to build with gcc. May give it a try.
Well, yes, It can definitely be done → it just needs a restructure of the “Buffer” class for GCC compilation.
I was also wondering if there is a simple encoder/decoder code in C or C++ that is structured like:
The examples I found are structured around a queue and threads (to be optimized I guess) and it’s hard for me to reconstruct them for my purposes :(
Since I would like to encode/decode a live stream from the camera that provides me with raw YUV and/or .h264 buffers
NvBuffer is an important structure and it is better to keep it. So it should be impossible to develop pure C code with jetson_multimedia_api.
Yeah :(
Is there a blueprint (a step-by-step guide) that could help me implement encoder/decoder scripts on my own?
