I use v4l2 input signal. I want use openv in \jetson_multimedia_api\samples\12_camera_v4l2_cuda.
How can I convert YUY420 NvBuffer to opencv mat?
This is my code,but it is not work.
static bool
start_capture(context_t * ctx)
struct sigaction sig_action;
struct pollfd fds[1];
NvBufferTransformParams transParams;
/* Register a shuwdown handler to ensure
a clean shutdown if user types <ctrl+c> */
sig_action.sa_handler = signal_handle;
sigemptyset(&sig_action.sa_mask);
sig_action.sa_flags = 0;
sigaction(SIGINT, &sig_action, NULL);
if (ctx->cam_pixfmt == V4L2_PIX_FMT_MJPEG)
ctx->jpegdec = NvJPEGDecoder::createJPEGDecoder("jpegdec");
/* Init the NvBufferTransformParams */
memset(&transParams, 0, sizeof(transParams));
transParams.transform_flag = NVBUFFER_TRANSFORM_FILTER | NVBUFFER_TRANSFORM_FLIP;
transParams.transform_filter = NvBufferTransform_Filter_Nicest; // NvBufferTransform_Filter_Smart
transParams.transform_flip = NvBufferTransform_None; // NvBufferTransform_Rotate90
/* Enable render profiling information */
ctx->renderer->enableProfiling();
fds[0].fd = ctx->cam_fd;
fds[0].events = POLLIN;
/* Wait for camera event with timeout = 5000 ms */
while (poll(fds, 1, 5000) > 0 && !quit)
if (fds[0].revents & POLLIN) {
struct v4l2_buffer v4l2_buf;
/* Dequeue a camera buff */
memset(&v4l2_buf, 0, sizeof(v4l2_buf));
v4l2_buf.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
if (ctx->capture_dmabuf)
v4l2_buf.memory = V4L2_MEMORY_DMABUF;
else
v4l2_buf.memory = V4L2_MEMORY_MMAP;
if (ioctl(ctx->cam_fd, VIDIOC_DQBUF, &v4l2_buf) < 0)
ERROR_RETURN("Failed to dequeue camera buff: %s (%d)",
strerror(errno), errno);
ctx->frame++;
/* Save the n-th frame to file */
if (ctx->frame == ctx->save_n_frame)
save_frame_to_file(ctx, &v4l2_buf);
if (ctx->cam_pixfmt == V4L2_PIX_FMT_MJPEG) {
int fd = 0;
uint32_t width, height, pixfmt;
unsigned int i = 0;
unsigned int eos_search_size = MJPEG_EOS_SEARCH_SIZE;
unsigned int bytesused = v4l2_buf.bytesused;
uint8_t *p;
/* v4l2_buf.bytesused may have padding bytes for alignment
Search for EOF to get exact size */
if (eos_search_size > bytesused)
eos_search_size = bytesused;
for (i = 0; i < eos_search_size; i++) {
p =(uint8_t *)(ctx->g_buff[v4l2_buf.index].start + bytesused);
if ((*(p-2) == 0xff) && (*(p-1) == 0xd9)) {
break;
bytesused--;
/* Decoding MJPEG frame */
if (ctx->jpegdec->decodeToFd(fd, ctx->g_buff[v4l2_buf.index].start,
bytesused, pixfmt, width, height) < 0)
ERROR_RETURN("Cannot decode MJPEG");
/* Convert the decoded buffer to YUV420P */
if (-1 == NvBufferTransform(fd, ctx->render_dmabuf_fd,
&transParams))
ERROR_RETURN("Failed to convert the buffer");
} else {
if (ctx->capture_dmabuf) {
/* Cache sync for VIC operation since the data is from CPU */
NvBufferMemSyncForDevice(ctx->g_buff[v4l2_buf.index].dmabuff_fd, 0,
(void**)&ctx->g_buff[v4l2_buf.index].start);
} else {
/* Copies raw buffer plane contents to an NvBuffer plane */
Raw2NvBuffer(ctx->g_buff[v4l2_buf.index].start, 0,
ctx->cam_w, ctx->cam_h, ctx->g_buff[v4l2_buf.index].dmabuff_fd);
/* Convert the camera buffer from YUV422 to YUV420P */
if (-1 == NvBufferTransform(ctx->g_buff[v4l2_buf.index].dmabuff_fd, ctx->render_dmabuf_fd,
&transParams))
if (ctx->cam_pixfmt == V4L2_PIX_FMT_GREY) {
if(!nvbuff_do_clearchroma(ctx->render_dmabuf_fd))
ERROR_RETURN("Failed to clear chroma");
cuda_postprocess(ctx, ctx->render_dmabuf_fd);
/* Preview */
#if 1
cv::Mat display_img;
void *pdata = NULL;
NvBufferMemMap(ctx->render_dmabuf_fd, 0, NvBufferMem_Read, &pdata);
NvBufferMemSyncForCpu(ctx->render_dmabuf_fd, 0, &pdata);
cv::Mat imgbuf = cv::Mat(ctx->cam_h + (ctx->cam_h >> 1),
ctx->cam_w,
CV_8UC1, pdata);
cvtColor(imgbuf, display_img, cv::COLOR_YCrCb2BGR);
NvBufferMemUnMap(ctx->render_dmabuf_fd, 0, &pdata);
cv::imshow("img", display_img);
#else
ctx->renderer->render(ctx->render_dmabuf_fd);
#endif
/* Enqueue camera buffer back to driver */
if (ioctl(ctx->cam_fd, VIDIOC_QBUF, &v4l2_buf))
ERROR_RETURN("Failed to queue camera buffers: %s (%d)",
/* Print profiling information when streaming stops */
ctx->renderer->printProfilingStats();
delete ctx->jpegdec;
return true;
