Hi
I am trying to load keras model (image classification Good Vs Fail, 300x300 images, 7000 images in total, dataset data augumentation used)into my 2 GB jeton nano (LXDE mode). However i keep facing the out of memory issue even before model optimisation using tensorrt. Please i need some advise about the way to follow in order to deploy this model into the board. Thank you
Modeling:
backend.clear_session()
model = Sequential()
model.add(Conv2D(filters=16, kernel_size=(7,7), strides=2, input_shape=image_shape, activation=‘relu’, padding=‘same’))
model.add(MaxPooling2D(pool_size=(2, 2), strides=2))
model.add(Conv2D(filters=32, kernel_size=(3,3), strides=1, input_shape=image_shape, activation=‘relu’, padding=‘same’))
model.add(Conv2D(filters=64, kernel_size=(3,3), strides=1, input_shape=image_shape, activation=‘relu’, padding=‘same’))
model.add(Flatten())
model.add(Dense(units=8, activation=‘relu’))
model.add(Dropout(rate=0.2))
model.add(Dense(units=1, activation=‘sigmoid’))
model.compile(loss=‘binary_crossentropy’, optimizer=‘adam’, metrics=[‘accuracy’])
