Deepstream out of memory when transfer the onnx model into engine on Jetson Nano board
Dear my frineds,
Now I am trying to run the deepstream_pose_estimation porject on Jetson Nano board.
When I run the project first time , deepstream has to transfer the pose_estimation.onnx model into a engine file, it leads to out of memory issue.
LOG:
deepstream-pose invoked oom-killer: gfp_mask=0x240B2c2(GPP_KERNEL…
Out of memory: Kill process 16547 (deepstream-pose) score 142 or sacrifice child
I run the same project on T4 GPU, it takes a lot of GPU memory the first for the onnx model transfer, after the engine file generated, less memory is required.
How can I achieve this onnx model transfer on Jetson Nano board???
Thx
**• Hardware Platform (Jetson / GPU) JETSON
**• DeepStream Version 5.1
**• JetPack Version (valid for Jetson only) 4.5
**• TensorRT Version 7.1
Please add some swap memory to see if it helps first:
Thx my friend.
To solve this problem I used trtexec in tensorrt to generate the engine file at first
