Run deepstream-bodypose2d-app demo but the output file is 0kb
Hardware (Jetson Nano 4G)
deepstream-app version 6.0.0
DeepStreamSDK 6.0.0
CUDA Driver Version: 10.2
CUDA Runtime Version: 10.2
TensorRT Version: 8.0
cuDNN Version: 8.2
I clone the project by this:
nvidia@nano:~/ds6_test$ git clone -b release/tao3.0_ds6.0ga GitHub - NVIDIA-AI-IOT/deepstream_tao_apps: Sample apps to demonstrate how to deploy models trained with TAO on DeepStream
and download the model.
Then I run referring the page:
nvidia@nano:~/ds6_test/deepstream_tao_apps/apps/tao_others/deepstream-bodypose2d-app$ ./deepstream-bodypose2d-app 1 …/…/…/configs/bodypose2d_tao/sample_bodypose2d_model_config.txt file:///opt/nvidia/deepstream/deepstream-6.0/samples/streams/sample_720p.jpg ./body2dout
When rebuilding the engine, it occurred some issues:
WARNING: [TRT]: Skipping tactic 21 due to oom error on requested size of 1728 detected for tactic -1218658103698133241.
ERROR: [TRT]: Tactic Device request: 1728MB Available: 1536MB. Device memory is insufficient to use tactic.
WARNING: [TRT]: Skipping tactic 22 due to oom error on requested size of 1728 detected for tactic -836875257600482091.
WARNING: [TRT]: Skipping tactic 23 due to oom error on requested size of 1728 detected for tactic -410470605513481746.
WARNING: [TRT]: Skipping tactic 0 due to oom error on requested size of 1728 detected for tactic -9153228964338181824.
WARNING: [TRT]: Skipping tactic 1 due to oom error on requested size of 1728 detected for tactic -7394439838318485025.
WARNING: [TRT]: Skipping tactic 0 due to oom error on requested size of 1728 detected for tactic 1002.
WARNING: [TRT]: Skipping tactic 1 due to oom error on requested size of 1728 detected for tactic 0.
WARNING: [TRT]: Internal error: cannot reformat, disabling format. Try decreasing the workspace size with IBuilderConfig::setMaxWorkspaceSize().
WARNING: [TRT]: Memory requirements of format conversion cannot be satisfied during timing, format rejected.
0:23:43.027788485  8437   0x5574cac830 INFO                 nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary-infer-engine1> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1947> [UID = 1]: serialize cuda engine to file: /opt/nvidia/deepstream/deepstream-6.0/sources/apps/sample_apps/deepstream_tao_apps/models/bodypose2d/model.etlt_b32_gpu0_fp16.engine successfully
INFO: [FullDims Engine Info]: layers num: 3
0   INPUT  kFLOAT input_1:0       288x384x3       min: 1x288x384x3     opt: 32x288x384x3    Max: 32x288x384x3
1   OUTPUT kFLOAT heatmap_out/BiasAdd:0 36x48x19        min: 0               opt: 0               Max: 0
2   OUTPUT kFLOAT conv2d_transpose_1/BiasAdd:0 144x192x38      min: 0               opt: 0               Max: 0
Killed
I think it should be low memory, but finally I think it runs successful.
However, the output file is just 0kb, it is just an empty file.
Is there any way to fix it? THx.
And I try to run another app,
nvidia@nano:~/ds6_test/deepstream_tao_apps/apps/tao_others/deepstream-gesture-app$ ./deepstream-gesture-app 2 …/…/…/configs/bodypose2d_tao/sample_bodypose2d_model_config.txt file:///opt/nvidia/deepstream/deepstream-6.0/samples/streams/sample_720p.jpg ./gesture
it just output the usage.
Is there a problem with my operation?
From the log, it is “Killed”. So, it does not run successfully.
Please refer to deepstream_tao_apps/apps/tao_others at master · NVIDIA-AI-IOT/deepstream_tao_apps · GitHub
A sample of gesture:
./deepstream-gesture-app 1 1 ../../../configs/bodypose2d_tao/sample_bodypose2d_model_config.txt file:///usr/data/bodypose2d_test.png ./gesture
Thanks for your reply.
The engine is built successfully, but when I run again, it just displays killed.
nvidia@nano:~/ds6_test/deepstream_tao_apps/apps/tao_others/deepstream-bodypose2d-app$  ./deepstream-bodypose2d-app 1 ../../../configs/bodypose2d_tao/sample_bodypose2d_model_config.txt file:///opt/nvidia/deepstream/deepstream-6.0/samples/streams/sample_720p.jpg ./body2dout
Request sink_0 pad from streammux
joint Edges 1 , 8
joint Edges 8 , 9
joint Edges 9 , 10
joint Edges 1 , 11
joint Edges 11 , 12
joint Edges 12 , 13
joint Edges 1 , 2
joint Edges 2 , 3
joint Edges 3 , 4
joint Edges 2 , 16
joint Edges 1 , 5
joint Edges 5 , 6
joint Edges 6 , 7
joint Edges 5 , 17
joint Edges 1 , 0
joint Edges 0 , 14
joint Edges 0 , 15
joint Edges 14 , 16
joint Edges 15 , 17
connections 0 , 1
connections 1 , 2
connections 1 , 5
connections 2 , 3
connections 3 , 4
connections 5 , 6
connections 6 , 7
connections 2 , 8
connections 8 , 9
connections 9 , 10
connections 5 , 11
connections 11 , 12
connections 12 , 13
connections 0 , 14
connections 14 , 16
connections 8 , 11
connections 15 , 17
connections 0 , 15
Now playing: file:///opt/nvidia/deepstream/deepstream-6.0/samples/streams/sample_720p.jpg
0:00:06.187699234 20930   0x55c556c8d0 INFO                 nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary-infer-engine1> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.0/sources/apps/sample_apps/deepstream_tao_apps/models/bodypose2d/model.etlt_b32_gpu0_fp16.engine
0:00:06.187985022 20930   0x55c556c8d0 INFO                 nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary-infer-engine1> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2004> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.0/sources/apps/sample_apps/deepstream_tao_apps/models/bodypose2d/model.etlt_b32_gpu0_fp16.engine
Killed
For gesture:
I am trying
./deepstream-gesture-app 1 1 …/…/…/configs/bodypose2d_tao/sample_bodypose2d_model_config.txt file:///opt/nvidia/deepstream/deepstream-6.0/samples/streams/sample_720p.jpg ./gesture
but the same result:
WARNING: [TRT]: Detected invalid timing cache, setup a local cache instead
0:00:52.364826100 20941   0x55ba8b14c0 INFO                 nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<second-infer-engine> NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1947> [UID = 2]: serialize cuda engine to file: /opt/nvidia/deepstream/deepstream-6.0/sources/apps/sample_apps/deepstream_tao_apps/models/gesture/gesture.etlt_b8_gpu0_fp16.engine successfully
INFO: [FullDims Engine Info]: layers num: 2
0   INPUT  kFLOAT input_1         3x160x160       min: 1x3x160x160     opt: 8x3x160x160     Max: 8x3x160x160
1   OUTPUT kFLOAT activation_18   6               min: 0               opt: 0               Max: 0
0:00:52.430272170 20941   0x55ba8b14c0 INFO                 nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<second-infer-engine> [UID 2]: Load new model:../../../configs/gesture_tao/gesture_sgie_config.txt sucessfully
0:00:53.855999543 20941   0x55ba8b14c0 INFO                 nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary-infer-engine1> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.0/sources/apps/sample_apps/deepstream_tao_apps/models/bodypose2d/model.etlt_b32_gpu0_fp16.engine
0:00:53.856160011 20941   0x55ba8b14c0 INFO                 nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary-infer-engine1> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2004> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.0/sources/apps/sample_apps/deepstream_tao_apps/models/bodypose2d/model.etlt_b32_gpu0_fp16.engine
Killed
So the problem is the engine? How can I solve this problem?
It is due to out of memory.
Please check if you can kill some other application to improve the memory.
Or, please try to use dgpu machines or other Jetson devices.
OK. I try to close the desktop display and it runs successfully.
nvidia@nano:~/ds6_test/deepstream_tao_apps/apps/tao_others/deepstream-bodypose2d-app$ sudo init 3
nvidia@nano:~/ds6_test/deepstream_tao_apps/apps/tao_others/deepstream-bodypose2d-app$ export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/opt/nvidia/deepstream/deepstream/lib/cvcore_libs
nvidia@nano:~/ds6_test/deepstream_tao_apps/apps/tao_others/deepstream-bodypose2d-app$ unset DISPLAY
nvidia@nano:~/ds6_test/deepstream_tao_apps/apps/tao_others/deepstream-bodypose2d-app$ ./deepstream-bodypose2d-app 1 ../../../configs/bodypose2d_tao/sample_bodypose2d_model_config.txt file:///opt/nvidia/deepstream/deepstream-6.0/samples/streams/original-image.png ./body2dout
but log on screen still is warning.
Then I try to recover the display, run
nvidia@nano:~/ds6_test/deepstream_tao_apps/apps/tao_others/deepstream-bodypose2d-app$ sudo init 5
Input the passwd, but some error occurred:
How can I fix this?
Reboot is useful, is there another solution?
Thx.
For “recover the display in Nano”, please create a new topic in Jetson Nano forum. Thanks.
OK,sorry.
