Jetson nano 4gb, the green light is turning on for 2secs and turning off when It connected to power supply(5v - 2amp usb)
I’m facing this problem with my Jetson Nano 4GB. After the 1st boot up and set up using headless mode, i powered it with 5v-2.5amp usb but the green led turning on for 2 seconds then turning off. And also when i connected to the laptop it is not showing up in ports (COM).
Please help me
Are you using the devkit or custom board?
Do you tried to power it up with DC (with jumper) instead of USB (w/o jumper)?
Could you provide UART console log for further check?
Jetson Nano Style - Serial Console
  1. I am using jetson nano 4GB dev kit
  2. While doing headless mode setup I used barrel jack power supply with jumper
  3. While connecting with USB power supply I didn’t removed for first time, after noticing I removed jumper and tried powering up but the green light turned on for 2secs and turned off
  4. For UART console log, now I don’t have USB to TTL serial cable after getting I will share
How did you flash the devkit?
The devkit would boot up once it is powered. (either by power jack or Micro-USB)
  • Use jumper for power jack
  • Remove jumper for Micro-USB
It would need serial console cable to know what’s going on.
I followed the jetson nano Get started page,
First, I connected jetson nano to laptop and then I connected power supply to barrel jack.
Using putty I made the setup and configuration then I disconnected the power supply and usb cable from laptop.
When I am trying to connect USB power supply without jumper, the issue of green light is arising.
What’s your host PC OS?
I would suggest using SDK Manager to re-flash the devkit before you get the UART console calbe.
SDKM is only available on Ubuntu, please use standalone Ubuntu host PC to re-flash.
Install Jetson Software with SDK Manager :: NVIDIA SDK Manager Documentation
And I think you just need to connect micro-USB w/o jumper as power supply and connection to host PC.
My host pc OS is window 11
Ok, I will try with SDK manger.
I tried with SDK manager, but it’s showing no board connected in hardware configuration.
Please help me
In this video, When I am connecting the jetson nano to my host machine, the green light on it, is turning on for 2 secs and turning off
Could you try entering Force Recovery Mode before running SDKM?
How to Put NVIDIA Jetson NANO in Force Recovery Mode? - #2 by WayneWWW
i tried with force recovery mode but flashing is failing after 60%.
error message:
16:07:31 INFO: Flash Jetson Nano - flash: copying tegraboot(/home/guduru/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/t210ref/nvtboot.bin)... done.
16:07:31 INFO: Flash Jetson Nano - flash: copying cpu_bootloader(/home/guduru/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
16:07:31 INFO: Flash Jetson Nano - flash: copying bpffile(/home/guduru/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/t210ref/sc7entry-firmware.bin)... done.
16:07:31 INFO: Flash Jetson Nano - flash: copying wb0boot(/home/guduru/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/t210ref/warmboot.bin)... done.
16:07:31 INFO: Flash Jetson Nano - flash: Existing eksfile(/home/guduru/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/eks.img) reused.
16:07:31 INFO: Flash Jetson Nano - flash: Copying nv_boot_control.conf to rootfs
16:07:32 INFO: Flash Jetson Nano - flash: populating kernel to rootfs... done.
16:07:32 INFO: Flash Jetson Nano - flash: populating initrd to rootfs... done.
16:07:32 INFO: Flash Jetson Nano - flash: Making system.img...
16:09:33 INFO: Flash Jetson Nano - flash: populating rootfs from /home/guduru/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/rootfs ...
16:13:06 INFO: Flash Jetson Nano - flash: populating /boot/extlinux/extlinux.conf ... done.
16:13:16 INFO: Flash Jetson Nano - flash: Sync'ing system.img ... done.
16:15:20 INFO: Flash Jetson Nano - flash: Converting RAW image to Sparse image...
16:15:35 INFO: Flash Jetson Nano - flash: done.
16:15:35 INFO: Flash Jetson Nano - flash: system.img built successfully.
16:15:35 INFO: Flash Jetson Nano - flash: Existing tbcfile(/home/guduru/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
16:15:36 INFO: Flash Jetson Nano - flash: copying tbcdtbfile(/home/guduru/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-b00.dtb)... done.
16:15:37 INFO: Flash Jetson Nano - flash: copying cfgfile(/home/guduru/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/t210ref/cfg/flash_l4t_t210_max-spi_sd_p3448.xml) to flash.xml... done.
16:15:37 INFO: Flash Jetson Nano - flash: copying flasher(/home/guduru/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
16:15:37 INFO: Flash Jetson Nano - flash: Existing flashapp(/home/guduru/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py) reused.
16:15:37 INFO: Flash Jetson Nano - flash: saving flash command in /home/guduru/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/flashcmd.txt
16:15:37 INFO: Flash Jetson Nano - flash: saving Windows flash command to /home/guduru/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/flash_win.bat
16:15:38 INFO: Flash Jetson Nano - flash: assign_value: crc-flash.xml.bin 1 65520 1
16:15:38 INFO: Flash Jetson Nano - flash: printf '\x1' | dd of=crc-flash.xml.bin bs=1 seek=65520 count=1 conv=notrunc
16:15:38 INFO: Flash Jetson Nano - flash: assign_value: crc-flash.xml.bin 0 65521 1
16:15:38 INFO: Flash Jetson Nano - flash: echo PTHD | dd of=crc-flash.xml.bin bs=1 seek=65528 count=4 conv=notrunc
16:15:38 INFO: Flash Jetson Nano - flash: *** Flashing target device started. ***
16:15:38 ERROR: Flash Jetson Nano - flash: 4 bytes copied, 0.000103206 s, 38.8 kB/s
16:15:41 INFO: Flash Jetson Nano - flash: [ 0.0102 ] tegrasign --getmode mode.txt --key None
16:15:41 INFO: Flash Jetson Nano - flash: [ 0.0435 ] RCM 1 is saved as rcm_1.rcm
16:15:41 INFO: Flash Jetson Nano - flash: [ 0.0469 ] Assuming zero filled SBK key
16:15:41 INFO: Flash Jetson Nano - flash: [ 0.0538 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
16:15:41 INFO: Flash Jetson Nano - flash: [ 0.0568 ] tegraparser --pt flash.xml.tmp
16:15:41 INFO: Flash Jetson Nano - flash: [ 0.0597 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --list images_list.xml
16:15:41 INFO: Flash Jetson Nano - flash: [ 0.1246 ] Assuming zero filled SBK key
16:15:41 INFO: Flash Jetson Nano - flash: [ 0.2345 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.cfg --chip 0x21 0
16:15:41 INFO: Flash Jetson Nano - flash: [ 0.2504 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
16:15:41 INFO: Flash Jetson Nano - flash: [ 0.2795 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
16:15:41 INFO: Flash Jetson Nano - flash: [ 0.2927 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatebfsinfo flash.xml.bin
16:15:41 INFO: Flash Jetson Nano - flash: [ 0.2965 ] BR_CID: 0x32101001643073071800000017020080
16:15:41 INFO: Flash Jetson Nano - flash: [ 0.3239 ] RCM version 0X210001
16:15:42 INFO: Flash Jetson Nano - flash: [ 1.3838 ] tegrarcm --download bct P3448_A00_lpddr4_204Mhz_P987.bct
16:15:42 INFO: Flash Jetson Nano - flash: [ 1.4152 ] [...] 100%
16:15:42 INFO: Flash Jetson Nano - flash: Command tegrarcm --download bct P3448_A00_lpddr4_204Mhz_P987.bct
16:15:42 ERROR: Flash Jetson Nano - flash: Failed flashing t210ref.
16:15:42 ERROR: Flash Jetson Nano - flash: *** ERROR: flashing failed.
16:15:43 INFO: Flash Jetson Nano - flash: [host] [ 9.65 GB used. Disk Avail: 7.90 GB ]
16:15:43 ERROR: Flash Jetson Nano - flash: command terminated with error
16:15:44 SUMMARY: DateTime Target Setup - target: Depends on failed component
please help me
thanks
flash failed at 99%
error code:
01:24:35 INFO: Flash Jetson Nano - flash: [ 1.0572 ] Warning: No sdram params
01:24:35 INFO: Flash Jetson Nano - flash: [ 1.0577 ]
01:24:35 INFO: Flash Jetson Nano - flash: [ 1.0577 ] Updating bl info
01:24:35 INFO: Flash Jetson Nano - flash: [ 1.0614 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
01:24:35 INFO: Flash Jetson Nano - flash: [ 1.0862 ]
01:24:35 INFO: Flash Jetson Nano - flash: [ 1.0862 ] Updating secondary storage information into bct
01:24:35 INFO: Flash Jetson Nano - flash: [ 1.0888 ] tegraparser --pt flash.xml.bin --chip 0x21 0 --updatecustinfo P3448_A00_lpddr4_204Mhz_P987.bct
01:24:35 INFO: Flash Jetson Nano - flash: [ 1.1197 ]
01:24:35 INFO: Flash Jetson Nano - flash: [ 1.1198 ] Updating Odmdata
01:24:35 INFO: Flash Jetson Nano - flash: [ 1.1230 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatefields Odmdata =0xa4000
01:24:35 INFO: Flash Jetson Nano - flash: [ 1.1248 ] Warning: No sdram params
01:24:35 INFO: Flash Jetson Nano - flash: [ 1.1253 ]
01:24:35 INFO: Flash Jetson Nano - flash: [ 1.1253 ] Get Signed section of bct
01:24:35 INFO: Flash Jetson Nano - flash: [ 1.1285 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --listbct bct_list.xml
01:24:35 INFO: Flash Jetson Nano - flash: [ 1.1302 ]
01:24:35 INFO: Flash Jetson Nano - flash: [ 1.1303 ] Signing BCT
01:24:35 INFO: Flash Jetson Nano - flash: [ 1.1353 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
01:24:35 INFO: Flash Jetson Nano - flash: [ 1.1363 ] Assuming zero filled SBK key
01:24:35 INFO: Flash Jetson Nano - flash: [ 1.1371 ]
01:24:35 INFO: Flash Jetson Nano - flash: [ 1.1371 ] Updating BCT with signature
01:24:35 INFO: Flash Jetson Nano - flash: [ 1.1397 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatesig bct_list_signed.xml
01:24:35 INFO: Flash Jetson Nano - flash: [ 1.1408 ]
01:24:35 INFO: Flash Jetson Nano - flash: [ 1.1408 ] Copying signatures
01:24:35 INFO: Flash Jetson Nano - flash: [ 1.1429 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
01:24:35 INFO: Flash Jetson Nano - flash: [ 1.1684 ]
01:24:35 INFO: Flash Jetson Nano - flash: [ 1.1685 ] Updating BFS information on BCT
01:24:35 INFO: Flash Jetson Nano - flash: [ 1.1706 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatebfsinfo flash.xml.bin
01:24:36 INFO: Flash Jetson Nano - flash: [ 1.1715 ]
01:24:36 INFO: Flash Jetson Nano - flash: [ 1.1716 ] Boot Rom communication
01:24:36 INFO: Flash Jetson Nano - flash: [ 1.1734 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml
01:24:36 INFO: Flash Jetson Nano - flash: [ 1.1740 ] BR_CID: 0x32101001643073071800000017020080
01:24:36 INFO: Flash Jetson Nano - flash: [ 1.2014 ] RCM version 0X210001
01:24:37 INFO: Flash Jetson Nano - flash: [ 1.2454 ] Boot Rom communication completed
01:24:37 INFO: Flash Jetson Nano - flash: [ 2.2527 ]
01:24:37 INFO: Flash Jetson Nano - flash: [ 2.2527 ] Sending BCTs
01:24:37 INFO: Flash Jetson Nano - flash: [ 2.2551 ] tegrarcm --download bct P3448_A00_lpddr4_204Mhz_P987.bct
01:24:37 INFO: Flash Jetson Nano - flash: [ 2.2562 ] Applet version 00.01.0000
01:24:37 INFO: Flash Jetson Nano - flash: [ 2.2833 ] Sending bct
01:24:37 INFO: Flash Jetson Nano - flash: [ 2.2834 ] [...] 100%
01:24:37 INFO: Flash Jetson Nano - flash: [ 2.3901 ]
01:24:37 ERROR: Flash Jetson Nano - flash: Error: Return value 8
01:24:37 INFO: Flash Jetson Nano - flash: Command tegrarcm --download bct P3448_A00_lpddr4_204Mhz_P987.bct
01:24:37 ERROR: Flash Jetson Nano - flash: Failed flashing t210ref.
01:24:37 ERROR: Flash Jetson Nano - flash: *** ERROR: flashing failed.
01:24:37 INFO: Flash Jetson Nano - flash: [ Component Install Finished with Error ]
01:24:38 INFO: Flash Jetson Nano - flash: [host] [ 6.26 GB used. Disk Avail: 27.17 GB ]
01:24:38 INFO: Flash Jetson Nano - flash: [ NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP Install took 23m51s ]
01:24:38 ERROR: Flash Jetson Nano - flash: command terminated with error
**01:24:39 SUMMARY: Flash Jetson Nano - flash: First Error: Installation failed.**
UART console log:
����[0000.125] [L4T TegraBoot] (version 00.00.2018.01-l4t-e82258de)
[0000.130] Processing in cold boot mode Bootloader 2
[0000.135] A02 Bootrom Patch rev = 1023
[0000.138] Power-up reason: pmc por
[0000.141] No Battery Present
[0000.144] pmic max77620 reset reason
[0000.147] pmic max77620 NVERC : 0xca
[0000.151] RamCode = 0
[0000.153] Platform has DDR4 type RAM
[0000.156] max77620 disabling SD1 Remote Sense
[0000.161] Setting DDR voltage to 1125mv
[0000.165] Serial Number of Pmic Max77663: 0xf1e34
[0000.172] Entering ramdump check
[0000.175] Get RamDumpCarveOut = 0x0
[0000.178] RamDumpCarveOut=0x0,  RamDumperFlag=0xe59ff3f8
[0000.184] Last reboot was clean, booting normally!
[0000.188] Sdram initialization is successful
[0000.192] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.198] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.204] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.210] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.216] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.222] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.228] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.233] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.250] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.256] Platform-DebugCarveout: 0
[0000.259] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.265] Non secure mode, and RB not enabled.
[0000.269] BoardID = 3448, SKU = 0x0
[0000.272] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.276] Nano-SD: checking PT table on QSPI ...
[0000.280] Read PT from (2:0)
[0000.296] Using BFS PT to query partitions
[0000.301] Loading Tboot-CPU binary
[0000.330] Verifying TBC in OdmNonSecureSBK mode
[0000.340] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.347] Bootloader downloaded successfully.
[0000.351] Downloaded Tboot-CPU binary to 0xa0000258
[0000.356] MAX77620_GPIO5 configured
[0000.359] CPU power rail is up
[0000.362] CPU clock enabled
[0000.366] Performing RAM repair
[0000.369] Updating A64 Warmreset Address to 0xa00002e9
[0000.374] BoardID = 3448, SKU = 0x0
[0000.377] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.381] Nano-SD: checking PT table on QSPI ...
[0000.385] Loading NvTbootBootloaderDTB
[0000.452] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.523] Bootloader DTB Load Address: 0x83000000
[0000.528] BoardID = 3448, SKU = 0x0
[0000.531] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.535] Nano-SD: checking PT table on QSPI ...
[0000.540] Loading NvTbootKernelDTB
[0000.606] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.679] Kernel DTB Load Address: 0x83100000
[0000.683] BoardID = 3448, SKU = 0x0
[0000.686] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.690] Nano-SD: checking PT table on QSPI ...
[0000.696] Loading cboot binary
[0000.147] pmic max77620 NVERC : 0x40
[0000.678] Kernel DTB Load Address: 0x83100000
[0000.812] Verifying EBT in OdmNonSecureSBK mode
[0000.853] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.860] Bootloader downloaded successfully.
[0000.865] BoardID = 3448, SKU = 0x0
[0000.868] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.872] Nano-SD: checking PT table on QSPI ...
[0000.876] PT: Partition NCT NOT found !
[0000.880] Warning: Find Partition via PT Failed
[0000.884] Next binary entry address: 0x92c00258
[0000.889] BoardId: 3448
[0000.893] Overriding pmu board id with proc board id
[0000.898] Display board id is not available
[0000.902] BoardID = 3448, SKU = 0x0
[0000.906] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.909] Nano-SD: checking PT table on QSPI ...
[0001.014] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0001.071] /bpmp deleted
[0001.073] SC7EntryFw header found loaded at 0xff700000
[0001.269] OVR2 PMIC
[0001.271] Bpmp FW successfully loaded
[0001.274] BoardID = 3448, SKU = 0x0
[0001.277] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.281] Nano-SD: checking PT table on QSPI ...
[0001.287] WB0 init successfully at 0xff780000
[0001.291] Set NvDecSticky Bits
[0001.294] GSC2 address ff53fffc value c0edbbcc
[0001.301] GSC MC Settings done
[0001.304] BoardID = 3448, SKU = 0x0
[0001.307] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.311] Nano-SD: checking PT table on QSPI ...
[0001.316] TOS Image length 53680
[0001.319]  Monitor size 53680
[0001.322]  OS size 0
[0001.337] Secure Os Aes-CMAC Verification Failed!
[0001.342] Error in NvTbootValidateTOS [11]
[0001.346] Validation of secure os failed!
[0001.349] Device Shutdown called ...
���������������������������������������������������������4�����
How did you flash your board? (SDKM or flash.sh script)
You said that you are using 4GB Jetson.
Why the flash log showed 16GB?
And another on showed 32GB?
Are you flashing to SD Card?
  1. Using SDKM
  2. yes, I am using jetson nano 4gb dev kit,
    those 16gb and 32 gb are from my host pc
I have a doubt, in the above image,
Download folder: is a path from host pc
Target HW image folder: which path should I add ?
Please explain about the paths in the above image
Are you using VM Ubuntu for SDKM?
Both these two path is from your host PC.
Download folder is to store the debian packages.
Target HW image folder is to store Jetpack SDK.
Just choose somewhere with available space to store data.
I am using dual booted machine with (windows 11 and ubuntu 18.04)
It should be fine with this configuration.
Just make sure that you have enough disk space on host PC due to large file downloaded while using SDKM.
Could you flash the devkit with SDKM successfully?
Have you tried other USB cable?
I created a 50gb separate partition in ubuntu and I created two folders one is for download folder and another is for target hw image folder
After completing 99%, flash failed
Have you tried to flash the devkit with the script (flash.sh)?
