I am trying to connect the audio module MAX98357.
This module one of the popular with Raspberry Pi projects.
If your microcontroller or microcomputer has digital audio capability, this amp is for you! It takes standard I2S digital audio input and, not only decodes it into analog, but also amplifies it directly into a speaker. Perfect for adding compact...
I connected the module pins according to this:
LRC → pin 35
BCLK → pin 12
DIN → pin 40
GND → pin 6
Vin → pin 2
Then updated my Jetson:
sudo apt-get install sox libsox-fmt-all - (for mp3 tracks)
Then configured the mixer:
amixer -c tegrasndt210ref cset name='I2S1 Mux' MVC1
amixer -c tegrasndt210ref cset name='MVC1 Mux' ADMAIF1
amixer -c tegrasndt210ref cset name='MVC1 Vol' 12000
And tested:
AUDIODEV=hw:tegrasndt210ref,0 play test.mp3
But no sound was out.
Do I miss something?
kayccc
November 10, 2019, 11:25pm
2
Hi josef.polin,
Could you refer to the Audio Troubleshooting at L4T document to see if can help?
Hello!
On Jetson Nano the I2S interface on the 40-pin header is I2S4 and not I2S1 (see [0]). Therefore, you should not set the following …
In fact by default the I2S4 route should be configured. To undo the settings you have set, you should …
$ alsactl init tegrasndt210ref
After doing the above you should see that I2S4 is connected to the ADMAIF1 interface …
$ amixer -c tegrasndt210ref cget name='I2S4 Mux'
$ amixer -c tegrasndt210ref cget name='ADMAIF1 Mux'
Then you should just …
$ speaker-test -D hw:tegrasndt210ref,0 -c 2 -r 48000 -F S16_LE -t sine -f 500
Also I see that the MAX98357 has an SD_MODE pin that can place the device into shutdown and so you may wish to check that this pin is configured correctly.
Regards,
Jon
[0] Welcome — Jetson Linux<br/>Developer Guide 34.1 documentation
