I got it working, but I don’t think that I really did anything special - I did recompile the kernel with some more modules enabled, but for unrelated reasons.
The disk I use is the Adata SX6000 Lite 128gb. (Getting between 144MB/s and 200MB/s read)
I did more or less exactly the same as in the OP, but I used dd to clone the SD card, so that I have the other partitions as well in case I need them in future.
I experienced the same errors on the first power up, but it worked after a reboot. It seems to keep on giving the error on first power up. So it might be a signal integrity issue.
The adapter I got is this one:
https://www.aliexpress.com/item/32963836444.html
It comes with a 10cm,20cm and 30cm extension. I was worried about signal integrity, so I have not tried the longer ones. Once it succeeds in booting, it works and I don’t see any errors further-on so I think the initialization sequence is more sensitive to errors.
sudo hdparm -tT --direct /dev/nvme0n1
/dev/nvme0n1:
Timing O_DIRECT cached reads: 350 MB in 2.01 seconds = 174.39 MB/sec
Timing O_DIRECT disk reads: 532 MB in 3.01 seconds = 176.79 MB/sec
From the disk speeds you are getting, it seems that yours is running in pcie gen2, while I’m only getting gen1. Although, I do vaguely remember getting better speeds at some point while booting off the SD…
lspci -vv
01:00.0 Non-Volatile memory controller: Realtek Semiconductor Co., Ltd. Device 5762 (rev 01) (prog-if 02 [NVM Express])
Subsystem: Realtek Semiconductor Co., Ltd. Device 5762
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 84
Region 0: Memory at 13000000 (64-bit, non-prefetchable)
Region 5: Memory at 13004000 (32-bit, non-prefetchable)
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [50] MSI: Enable- Count=1/8 Maskable- 64bit+
Address: 0000000000000000 Data: 0000
Capabilities: [70] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s unlimited, L1 unlimited
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0.000W
DevCtl: Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported+
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop- FLReset-
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
LnkCap: Port #0, Speed 8GT/s, Width x4, ASPM L1, Exit Latency L0s unlimited, L1 <64us
ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
LnkCtl: ASPM L1 Enabled; RCB 64 bytes Disabled- CommClk+
ExtSynch- ClockPM+ AutWidDis- BWInt- AutBWInt-
LnkSta: <b>Speed 2.5GT/s, Width x1</b>, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Not Supported, TimeoutDis+, LTR+, OBFF Via message/WAKE#
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR+, OBFF Disabled
LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Capabilities: [b0] MSI-X: Enable+ Count=8 Masked-
Vector table: BAR=0 offset=00002000
PBA: BAR=0 offset=00003000
Capabilities: [100 v2] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
Capabilities: [148 v1] Device Serial Number 00-00-00-01-00-4c-e0-00
Capabilities: [158 v1] #19
Capabilities: [178 v1] Latency Tolerance Reporting
Max snoop latency: 0ns
Max no snoop latency: 0ns
Capabilities: [180 v1] L1 PM Substates
L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
PortCommonModeRestoreTime=60us PortTPowerOnTime=60us
L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2+ ASPM_L1.1+
T_CommonMode=0us LTR1.2_Threshold=131072ns
L1SubCtl2: T_PwrOn=70us
Kernel driver in use: nvme
