I wanted to back up the image in the SD card. In the nano environment, I used the command sudo dd bs=4M if=/home/nano.img (later I found that it should be used on the host). The system cannot be started normally after automatic restart.
how can I solve it, at least be able to copy out some important documents.
thanks a lot, my board is jetson nano A01, and now it can not booting up normally, it is stuck in this interface
[OK] Start update UTMP about System Runlevel Changes
