Jetson Nano doesn't recognize SD card
I use the Auvidea Carrier Board JNX30 and want to enable the MicroSD card slot. Additionally, I have BSP 32.6.1 and the Nvidia Jetson Nano production module. I followed this guide MicroSD card not detected on Jetson Nano production module but the MicroSD card is still not detected. I use the flash script to flash the Jetson Nano production module.
This is my lsblk output:
NAME         MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
loop0          7:0    0    16M  1 loop
mmcblk0      179:0    0  14,7G  0 disk
├─mmcblk0p1  179:1    0    14G  0 part /
├─mmcblk0p2  179:2    0     1M  0 part
├─mmcblk0p3  179:3    0     6M  0 part
├─mmcblk0p4  179:4    0    80K  0 part
├─mmcblk0p5  179:5    0    64M  0 part
├─mmcblk0p6  179:6    0     1M  0 part
├─mmcblk0p7  179:7    0     6M  0 part
├─mmcblk0p8  179:8    0    80K  0 part
├─mmcblk0p9  179:9    0    64M  0 part
├─mmcblk0p10 179:10   0   192K  0 part
├─mmcblk0p11 179:11   0   256K  0 part
├─mmcblk0p12 179:12   0    63M  0 part
├─mmcblk0p13 179:13   0   512K  0 part
├─mmcblk0p14 179:14   0   256K  0 part
├─mmcblk0p15 179:15   0   256K  0 part
├─mmcblk0p16 179:16   0   300M  0 part
└─mmcblk0p17 179:17   0 185,4M  0 part
mmcblk0boot0 179:32   0     4M  1 disk
mmcblk0boot1 179:64   0     4M  1 disk
mmcblk0rpmb  179:96   0     4M  0 disk
zram0        252:0    0 494,5M  0 disk [SWAP]
zram1        252:1    0 494,5M  0 disk [SWAP]
zram2        252:2    0 494,5M  0 disk [SWAP]
zram3        252:3    0 494,5M  0 disk [SWAP]
I have changed the following files like this:
tegra210-porg-plugin-manager.dtsi
 fragement@9 {
                        ids = "<3448-0000-300", "<3448-0002-300";
                        override@0 {
                                target = <&max77620_ldo6>;
                                _overlay_ {
                                        status = "disabled";
                        override@1 {
                                target = <&sdhci2>;
                                _overlay_ {
                                        keep-power-in-suspend;
                                        non-removable;
+                                       status = "okay";
tegra210-porg-p3448-common.dtsi
        sdhci@700b0400 {
+              status = "okay";
                /delete-property/ keep-power-in-suspend;
                /delete-property/ non-removable;
                mmc-ddr-1_8v;
                mmc-ocr-mask = <3>;
                uhs-mask = <0x0>;
                tap-delay = <3>;
tegra210-p3448-0002-p3449-0000-b00.dts
+  	sdhci@700b0400 { /* SD card custom carrier board */
+       	status = "okay"
tegra210-p2530-common.dtsi
        sdhci@700b0400 {
                mmc-ocr-mask = <0>;
                default-drv-type = <1>;
                uhs-mask = <0x1c>;
                power-off-rail;
                nvidia,update-pinctrl-settings;
+              status = "okay";
I also added the output of dmesg and lshw
dmesg.txt (70.9 KB)
lshw.txt (5.1 KB)
What am I doing wrong?
Thank you for your help in advance.
Suggest to contact with Auvidea support due to issue is related with their carrier board. Thanks
