Jetson nano not starting to train the data
i was working with the jetson nano for some project , when i tried to run the preloaded code for image classifaction all the code is working fine but when i started running the data it is taking forever
Could you share more info about your issue?
Which frameworks/samples do you use?
Does the training task take too long to run or get stuck?
i ran the preloaded classification and regression program on jupyter notebook
everything went fine but when i pressed the train button it was taking indefinite time.
i tried on both the headless device(laptop) and jetson nano desktop but the same issue presents
Which frameworks do you use?
Do you meet this with jetson_inference?
i followed the steps of Getting Started with Jetson Nano. The classification code was already preloaded into the jetson nano , i just followed the steps for the classification project which was provided in the jupyter notebook .
my issue is more of the same as this one :
can you please help me further
Have you checked the suggestion from the link you shared?
Disconnecting the display might help.
