Jetson Nano (Not the Orin) V4L2 and the IMX219 Camera Sensor
So I’m trying to use a Jetson Nano, Video For Linux 2, OpenCV, and an IMX219 camera sensor just to capture a single image and use cv::imshow() to display the captured image to the user.
I used ChatGPT to generate the code so I can have somewhat of a framework since I have no idea where to start when it comes to the actual V4L2 documentation.
I’m just trying to capture a 1280x720 image in the YUYV pixel format as shown in the code below, but for some reason, the code always gets ‘hung up’ here
    if (ioctl(fd, VIDIOC_DQBUF, &buffer) < 0)
        perror("Failed to dequeue buffer");
        munmap(buffer_start, buffer.length);
        close(fd);
        return 1;
Here’s the generated code in it’s entirely
#include <iostream>
#include <string>
#include <fcntl.h>
#include <unistd.h>
#include <sys/ioctl.h>
#include <linux/videodev2.h>
#include <errno.h>
#include <sys/mman.h>
#include <fstream>
#include <cstring>
// g++ -o v4l2_test v4l2_test.cpp
int main()
    // Open the video device
    int fd = open("/dev/video0", O_RDWR);
    if (fd < 0)
        perror("Failed to open device");
        return 1;
    // Query the device capabilities
    struct v4l2_capability cap;
    if (ioctl(fd, VIDIOC_QUERYCAP, &cap) < 0)
        perror("Failed to get device capabilities");
        close(fd);
        return 1;
    // Set the format
    struct v4l2_format format;
    format.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
    // format.fmt.pix.pixelformat = V4L2_PIX_FMT_SRGGB10; // Replace with the actual FourCC code
    format.fmt.pix.pixelformat = V4L2_PIX_FMT_YUYV;
    format.fmt.pix.width = 1280; // Adjust to your desired resolution
    format.fmt.pix.height = 720; // Adjust to your desired resolution
    if (ioctl(fd, VIDIOC_S_FMT, &format) < 0)
        perror("Failed to set format");
        close(fd);
        return 1;
    else
        printf("Format set\r\n");
    // Request buffers
    struct v4l2_requestbuffers req;
    req.count = 1;
    req.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
    req.memory = V4L2_MEMORY_MMAP;
    if (ioctl(fd, VIDIOC_REQBUFS, &req) < 0)
        perror("Failed to request buffers");
        close(fd);
        return 1;
    else
        printf("Buffer set\r\n");
    // Query the buffer
    struct v4l2_buffer buffer;
    memset(&buffer, 0, sizeof(buffer));
    buffer.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
    buffer.memory = V4L2_MEMORY_MMAP;
    buffer.index = 0;
    if (ioctl(fd, VIDIOC_QUERYBUF, &buffer) < 0)
        perror("Failed to query buffer");
        close(fd);
        return 1;
    else
        printf("Buffer queried\r\n");
    // Map the buffer
    void *buffer_start = mmap(NULL, buffer.length, PROT_READ | PROT_WRITE, MAP_SHARED, fd, buffer.m.offset);
    if (buffer_start == MAP_FAILED)
        perror("Failed to map buffer");
        close(fd);
        return 1;
    else
        printf("Buffer mapped\r\n");
    // Queue the buffer
    if (ioctl(fd, VIDIOC_QBUF, &buffer) < 0)
        perror("Failed to queue buffer");
        close(fd);
        return 1;
    else
        printf("Buffer queued agian\r\n");
    // Start streaming
    int type = buffer.type;
    if (ioctl(fd, VIDIOC_STREAMON, &type) < 0)
        perror("Failed to start streaming");
        close(fd);
        return 1;
    else
        printf("Stream started\r\n");
    // Dequeue the buffer
        close(fd);
        return 1;
    else
        printf("Buffer dequed\r\n");
    // Save the raw image data
    std::ofstream outFile("raw_frame.data", std::ios::binary);
    outFile.write((char *)buffer_start, buffer.bytesused);
    outFile.close();
    // Stop streaming
    if (ioctl(fd, VIDIOC_STREAMOFF, &type) < 0)
        perror("Failed to stop streaming");
    // Unmap the buffer and close device
    close(fd);
    std::cout << "Image captured and saved as captured_frame.ppm" << std::endl;
    return 0;
For what it’s worth, none of the perrors() get called and I’m not sure where to start troubleshooting at.
Sorry for the late response.
that’s incorrect format types.
I assume you’re using raspberry pi v2, imx219, right? then, it’s bayer sensor that output RGGB bayer formats.
