Hello Experts,
I am trying to use the default face_recognition (dlib, Pillow, numpy, etc) models in python as part of opencv2 library. When I tried to run it with CNN based models then the device hangs.
If your library is built with CUDA support, it should use cuDNN for inference automatically.
To check if dlib has GPU support, you can test it with the following command:
import dlib.cuda as cuda
print(cuda.get_num_devices())
