Could anyone tell me if dlib-gpu can work on jetson nano?
Firstly, I wanted to download CUDA10.1. But it was not compatible with ARM.
Then, I wanted to installed jetpack. Unfortunately, I still got AMD version. BTW, I read someone installed AMD version on nano successfully. So I confused about that.
I don’t have any idea about jetpack and even don’t know dlib-gpu can work or not. Becasue I read a post said that there were some problem with nano’s gpu. But that post was opend in 2020. Therefore, I haven’t known this problem was fixed yet.
The dlib-gpu migth be not supported, need to confirm.
Does that mean we just can use dlib-cpu on Nano?
Could you tell me how to install jetpack successfully?
We have confirmed that dlib-19.21 is working on the Jetson.
For other versions, you should be able to compile it in a similar way.
Thank you very much~
So I should install jetpack first then following these steps, right?
Or when I finalize these steps, I’ll install cuda and cudnn in the same time?
The steps only compile and install dlib library.
Please install JetPack components first.
Yes, thank you.
But I can install JetPack very well these days
So I would like to ask you if ypu have any recommand websites or steps can share me?
After you install all the JetPack components, please build dlib with the following instructions:
sorry my mistake. I meant the steps about jetpack.
