ART97
April 30, 2019, 5:27am
1
Hi
I am trying to install dlib for which I have already installed cmake.
cmake --version
cmake version 3.10.2
CMake suite maintained and supported by Kitware (kitware.com/cmake ).
After issuing command : pip3 install dlib
It keeps on building wheel for dlib. I waited to ~1hr but it didnt installed and was just showing building wheel for dlib. The nano however got freezed and wasnt responding so I restarted it but dlib was not installed.
How to properly installed dlib. Does the installtion takes this much time.?
Please wait it longer.
It really takes time since there are many dependencies need to be installed or compiled.
Flaty
April 30, 2019, 8:09am
3
same problem here. I tried
pip3 install face_recognition
I let finish the installation overnight and it ends always with the same error.
Failed building wheel for dlib
and
Command "/usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-g7g584gv/dlib/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-b072g57w-record/install-record.txt --single-version-externally-managed --compile --user --prefix=" failed with error code 1 in /tmp/pip-build-g7g584gv/dlib/
ART97
April 30, 2019, 9:24am
4
I had to build it from source and it took more than 2hr to install but dlib and face_recognition both are installed.
Python 3.6.7 (default, Oct 22 2018, 11:32:17)
[GCC 8.2.0] on linux
Type “help”, “copyright”, “credits” or “license” for more information.
import dlib
dlib.version
‘19.17.99’
import face_recognition
face_recognition.version
‘1.2.3’
But there is no point of using face_recognition on nano as it seems not to be working fine. It only detect face and not recognize them. While everything seems to be working fine on windows 10 laptop. I think its because of dlib issues. I have read in some other threads that dlib do not work properly on nano. I will try again.
Flaty
April 30, 2019, 12:08pm
5
On Raspberry Pi 3 dlib and face recognition works pretty well, but with low performance.
Flaty
May 3, 2019, 4:28pm
6
I have still trouble installing face_recognition.
I installed dlib from source with cmake with no errors.
wget http://dlib.net/files/dlib-19.17.tar.bz2
tar xvf dlib-19.17.tar.bz2
cd dlib-19.17/
mkdir build
cd build
cmake ..
cmake --build . --config Release
sudo make install
sudo ldconfig
then i installed it with python, no errors.
cd dlib-19.17
python setup.py install
but when i exec
python3
import dlib
dlib.__version__
I get the error: module ‘dlib’ has no attribute +‘version ’
is still failing.
I need help.
Thx for advice.
Flaty
May 7, 2019, 6:55am
7
I am still stuck on that problem.
We can install dlib/face_recognition with this command:
It looks like some issue in your dlib now.
Would you mind to reflash your device and install dlib with the command here:
https://devtalk.nvidia.com/default/topic/1049660/jetson-nano/issues-with-dlib-library/post/5336330/#5336330
This version also fixes a bug in face_encodings.
Flaty
May 10, 2019, 5:13pm
9
Ok, i increased the swapfile to 4GB and the Installation completed with no Errors.
Good to know this.
It looks like you are suffered from the out of memory issue.
Using Python 3.6, OpenCV, Dlib and the face_recognition module
Reading time: 17 min read
follow this link to install face recognition on Jetson nano as it builds dlib so that we can utilize the GPU of jetson nano.
