i want to communicate from jetson to microcontroller, i could successfully can read the data from the microcontroller, when i want to send the data from jetson to the microcontroller, the microcontroller is not receiving or not able to react.
i have used the ttl to usb converter from the jetson to the microcontroller and successfully read and write to the microcontroller
but when i am using with the ttl to ttl connecetion and via using serial.Serial(’/dev(ttyTHS1’, 57600) i can read but not write
i have tried with the disable the nvgetty or stop and reboot
i didn’t work
could anyone give me explaination or any solution .
thank you
