Jetson Nano v4l2_ioctl VIDIOC_STREAMOFF blocked
We use Jetson Nano NVENC to encoder 4 camera with 640x480. We referenced the Tegra_Multimedia_API_R32.2.0_aarch64. The jetpack version is 4.4 [L4T 32.4.3]. We need to change the bitrate occasionally, hence, the encoder may be exited and created new one.
In most cases, the function works fine. But it may be bolcked at v4l2_ioctl(fd, VIDIOC_STREAMOFF, &buf_type); in NvV4l2ElementPlane.cpp.
At that time, there are several logs by application shown as below:
NvRmChannelSubmit: NvError_IoctlFailed with error code 22
NvRmPrivFlush: NvRmChannelSubmit failed (err = 196623, SyncPointIdx = 7, SyncPointValue = 0)
fence_set_name ioctl failed with 22
NvMMLiteVideoEncDoWork:NvMSEncConvertSurfaceFormat failed
VENC: NvMMLiteVideoEncDoWork: 4283: BlockSide error 0x4
NvVideoEnc: BlockError
NvVideoEncTransferOutputBufferToBlock: DoWork failed line# 667
NvVideoEnc: NvVideoEncTransferOutputBufferToBlock TransferBufferToBlock failed Line=678
We think it was print by nvbuf_utils probably. And of course there is kernel dmesg shown as below.
[152490.356974] smmu_dump_pagetable(): fault_address=0x00000000ff1a7200 pa=0x0000000000000200 bytes=1000 #pte=4 in L2
[152490.367380] mc-err: (19) csr_vicsrd: EMEM decode error on PDE or PTE entry
[152490.374364] mc-err:   status = 0x6000006c; addr = 0xff1a7200
[152490.380151] mc-err:   secure: no, access-type: read, SMMU fault: nr-nw-s
[152490.387684] smmu_dump_pagetable(): fault_address=0x00000000fe1a0000 pa=0x0000000000000000 bytes=1000 #pte=275 in L2
[152490.398261] mc-err: (19) csr_vicsrd: EMEM decode error on PDE or PTE entry
[152490.405275] mc-err:   status = 0x6000006c; addr = 0xfe1a0000
[152490.411105] mc-err:   secure: no, access-type: read, SMMU fault: nr-nw-s
[152494.205721] falcon 54340000.vic: pin_array_ids: could not get buf err=-22
[152494.212644] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152494.220286] falcon 54340000.vic: submit_add_gathers: failed to copy user inputs: class_ids=000000008c022e38 num_cmdbufs=2
[152494.232198] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152494.239966] (NULL device *): nvhost_sync_fence_set_name: failed to get fence
[152497.730324] falcon 54340000.vic: pin_array_ids: could not get buf err=-22
[152497.737401] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152497.746084] falcon 54340000.vic: submit_add_gathers: failed to copy user inputs: class_ids=000000008c022868 num_cmdbufs=2
[152497.757198] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152497.764845] (NULL device *): nvhost_sync_fence_set_name: failed to get fence
[152497.849457] smmu_dump_pagetable(): fault_address=0x00000000fd4f3000 pa=0x0000000000000000 bytes=1000 #pte=777 in L2
[152497.860009] mc-err: (19) csr_vicsrd: EMEM decode error on PDE or PTE entry
[152497.866994] mc-err:   status = 0x6000006c; addr = 0xfd4f3000
[152497.872759] mc-err:   secure: no, access-type: read, SMMU fault: nr-nw-s
[152497.880176] smmu_dump_pagetable(): fault_address=0x00000000f6760000 pa=0x0000000000000000 bytes=1000 #pte=718 in L2
[152497.890720] mc-err: (19) csr_vicsrd: EMEM decode error on PDE or PTE entry
[152497.897837] mc-err:   status = 0x6000006c; addr = 0xf6760000
[152497.903681] mc-err:   secure: no, access-type: read, SMMU fault: nr-nw-s
[152497.931569] falcon 54340000.vic: pin_array_ids: could not get buf err=-22
[152497.938586] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152497.946477] falcon 54340000.vic: submit_add_gathers: failed to copy user inputs: class_ids=000000008c023b08 num_cmdbufs=2
[152497.957689] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152497.965334] (NULL device *): nvhost_sync_fence_set_name: failed to get fence
[152498.014272] falcon 54340000.vic: pin_array_ids: could not get buf err=-22
[152498.021197] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152498.028884] falcon 54340000.vic: submit_add_gathers: failed to copy user inputs: class_ids=0000000094023328 num_cmdbufs=2
[152498.040044] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152498.047752] (NULL device *): nvhost_sync_fence_set_name: failed to get fence
[152498.083931] falcon 54340000.vic: pin_array_ids: could not get buf err=-22
[152498.090925] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152498.098623] falcon 54340000.vic: submit_add_gathers: failed to copy user inputs: class_ids=000000008c023b28 num_cmdbufs=2
[152498.109712] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152498.118126] (NULL device *): nvhost_sync_fence_set_name: failed to get fence
[152498.125353] mc-err: Too many MC errors; throttling prints
[152507.587766] smmu_dump_pagetable(): fault_address=0x00000000fb8c0000 pa=0x0000000000000000 bytes=1000 #pte=226 in L2
[152507.598405] mc-err: (19) csr_vicsrd: EMEM decode error on PDE or PTE entry
[152507.605477] mc-err:   status = 0x6000006c; addr = 0xfb8c0000
[152507.611315] mc-err:   secure: no, access-type: read, SMMU fault: nr-nw-s
[152507.618904] smmu_dump_pagetable(): fault_address=0x00000000fb6a0000 pa=0x0000000000000000 bytes=1000 #pte=509 in L2
[152507.629577] mc-err: (19) csr_vicsrd: EMEM decode error on PDE or PTE entry
[152507.636701] mc-err:   status = 0x6000006c; addr = 0xfb6a0000
[152507.642596] mc-err:   secure: no, access-type: read, SMMU fault: nr-nw-s
[152507.666741] falcon 54340000.vic: pin_array_ids: could not get buf err=-22
[152507.674075] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152507.681891] falcon 54340000.vic: submit_add_gathers: failed to copy user inputs: class_ids=000000008c023b88 num_cmdbufs=2
[152507.692969] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152507.700739] (NULL device *): nvhost_sync_fence_set_name: failed to get fence
[152507.848893] smmu_dump_pagetable(): fault_address=0x00000000fc660000 pa=0x0000000000000000 bytes=1000 #pte=459 in L2
[152507.859436] mc-err: (19) csr_vicsrd: EMEM decode error on PDE or PTE entry
[152507.866424] mc-err:   status = 0x6000006c; addr = 0xfc660000
[152507.872188] mc-err:   secure: no, access-type: read, SMMU fault: nr-nw-s
[152507.879718] smmu_dump_pagetable(): fault_address=0x00000000f9ce0000 pa=0x0000000000000000 bytes=1000 #pte=374 in L2
[152507.890303] mc-err: (19) csr_vicsrd: EMEM decode error on PDE or PTE entry
[152507.897323] mc-err:   status = 0x6000006c; addr = 0xf9ce0000
[152507.903156] mc-err:   secure: no, access-type: read, SMMU fault: nr-nw-s
[152507.925451] falcon 54340000.vic: pin_array_ids: could not get buf err=-22
[152507.932460] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152507.941315] falcon 54340000.vic: submit_add_gathers: failed to copy user inputs: class_ids=0000000094022ad8 num_cmdbufs=2
[152507.953191] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152507.960889] (NULL device *): nvhost_sync_fence_set_name: failed to get fence
[152508.174616] mc-err: Too many MC errors; throttling prints
[152508.204717] falcon 54340000.vic: pin_array_ids: could not get buf err=-22
[152508.211970] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152508.219626] falcon 54340000.vic: submit_add_gathers: failed to copy user inputs: class_ids=000000009402b868 num_cmdbufs=2
[152508.230698] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152508.238331] (NULL device *): nvhost_sync_fence_set_name: failed to get fence
[152510.624100] falcon 54340000.vic: pin_array_ids: could not get buf err=-22
[152510.631290] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152510.639254] falcon 54340000.vic: submit_add_gathers: failed to copy user inputs: class_ids=000000008c029428 num_cmdbufs=2
[152510.650506] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152510.658802] (NULL device *): nvhost_sync_fence_set_name: failed to get fence
[152511.145672] falcon 54340000.vic: pin_array_ids: could not get buf err=-22
[152511.153130] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152511.160976] falcon 54340000.vic: submit_add_gathers: failed to copy user inputs: class_ids=000000008c0229b8 num_cmdbufs=2
[152511.172163] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152511.179964] (NULL device *): nvhost_sync_fence_set_name: failed to get fence
[152517.083286] falcon 54340000.vic: pin_array_ids: could not get buf err=-22
[152517.090224] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152517.097859] falcon 54340000.vic: submit_add_gathers: failed to copy user inputs: class_ids=000000008c013d48 num_cmdbufs=2
[152517.109127] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152517.116872] (NULL device *): nvhost_sync_fence_set_name: failed to get fence
[152526.520754] falcon 54340000.vic: pin_array_ids: could not get buf err=-22
[152526.527667] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152526.535283] falcon 54340000.vic: submit_add_gathers: failed to copy user inputs: class_ids=0000000094023ef8 num_cmdbufs=2
[152526.546337] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152526.553982] (NULL device *): nvhost_sync_fence_set_name: failed to get fence
[152526.582084] falcon 54340000.vic: pin_array_ids: could not get buf err=-22
[152526.589034] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152526.597237] falcon 54340000.vic: pin_array_ids: could not get buf err=-22
[152526.597242] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152526.597258] falcon 54340000.vic: submit_add_gathers: failed to copy user inputs: class_ids=0000000094022ac8 num_cmdbufs=2
[152526.597261] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152526.597362] (NULL device *): nvhost_sync_fence_set_name: failed to get fence
[152526.641216] falcon 54340000.vic: submit_add_gathers: failed to copy user inputs: class_ids=000000008c02bf68 num_cmdbufs=2
[152526.652576] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152526.660263] (NULL device *): nvhost_sync_fence_set_name: failed to get fence
[152526.687366] falcon 54340000.vic: pin_array_ids: could not get buf err=-22
[152526.694297] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152526.701910] falcon 54340000.vic: submit_add_gathers: failed to copy user inputs: class_ids=000000008c02bf38 num_cmdbufs=2
[152526.712965] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152526.720596] (NULL device *): nvhost_sync_fence_set_name: failed to get fence
[152526.749058] falcon 54340000.vic: pin_array_ids: could not get buf err=-22
[152526.756020] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152526.763658] falcon 54340000.vic: submit_add_gathers: failed to copy user inputs: class_ids=000000008c02bc88 num_cmdbufs=2
[152526.774773] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152526.782472] (NULL device *): nvhost_sync_fence_set_name: failed to get fence
[152526.792580] smmu_dump_pagetable(): fault_address=0x00000000fe060000 pa=0x0000000000000000 bytes=1000 #pte=113 in L2
[152526.803171] mc-err: (19) csr_vicsrd: EMEM decode error on PDE or PTE entry
[152526.810171] mc-err:   status = 0x6000006c; addr = 0xfe060000
[152526.815963] mc-err:   secure: no, access-type: read, SMMU fault: nr-nw-s
[152526.824641] smmu_dump_pagetable(): fault_address=0x00000000fe060000 pa=0x0000000000000000 bytes=1000 #pte=113 in L2
[152526.835210] mc-err: (19) csr_vicsrd: EMEM decode error on PDE or PTE entry
[152526.842204] mc-err:   status = 0x6000006c; addr = 0xfe060000
[152526.847971] mc-err:   secure: no, access-type: read, SMMU fault: nr-nw-s
[152526.885311] smmu_dump_pagetable(): fault_address=0x00000000fd8e0000 pa=0x0000000000000000 bytes=1000 #pte=371 in L2
[152526.895863] mc-err: (19) csr_vicsrd: EMEM decode error on PDE or PTE entry
[152526.902858] mc-err:   status = 0x6000006c; addr = 0xfd8e0000
[152526.908617] mc-err:   secure: no, access-type: read, SMMU fault: nr-nw-s
[152526.944730] smmu_dump_pagetable(): fault_address=0x00000000ff617200 pa=0x0000000000000200 bytes=1000 #pte=2 in L2
[152526.955086] mc-err: (19) csr_vicsrd: EMEM decode error on PDE or PTE entry
[152526.962067] mc-err:   status = 0x6000006c; addr = 0xff617200
[152526.967837] mc-err:   secure: no, access-type: read, SMMU fault: nr-nw-s
[152527.002749] falcon 54340000.vic: pin_array_ids: could not get buf err=-22
[152527.009775] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152527.018729] falcon 54340000.vic: submit_add_gathers: failed to copy user inputs: class_ids=000000008c010958 num_cmdbufs=2
[152527.029813] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152527.030047] mc-err: Too many MC errors; throttling prints
[152527.043326] (NULL device *): nvhost_sync_fence_set_name: failed to get fence
[152527.067778] falcon 54340000.vic: pin_array_ids: could not get buf err=-22
[152527.074754] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152527.082494] falcon 54340000.vic: submit_add_gathers: failed to copy user inputs: class_ids=000000008c02b908 num_cmdbufs=2
[152527.085121] falcon 54340000.vic: pin_array_ids: could not get buf err=-22
[152527.085127] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152527.085140] falcon 54340000.vic: submit_add_gathers: failed to copy user inputs: class_ids=000000008c010568 num_cmdbufs=2
[152527.085143] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152527.085185] (NULL device *): nvhost_sync_fence_set_name: failed to get fence
[152527.107469] falcon 54340000.vic: pin_array_ids: could not get buf err=-22
[152527.107473] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152527.107486] falcon 54340000.vic: submit_add_gathers: failed to copy user inputs: class_ids=000000008c010b28 num_cmdbufs=2
[152527.107489] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152527.107542] (NULL device *): nvhost_sync_fence_set_name: failed to get fence
[152527.138400] falcon 54340000.vic: pin_array_ids: could not get buf err=-22
[152527.138405] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152527.138418] falcon 54340000.vic: submit_add_gathers: failed to copy user inputs: class_ids=000000008c010738 num_cmdbufs=2
[152527.138421] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152527.138473] (NULL device *): nvhost_sync_fence_set_name: failed to get fence
[152527.163274] falcon 54340000.vic: pin_array_ids: could not get buf err=-22
[152527.163280] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152527.163295] falcon 54340000.vic: submit_add_gathers: failed to copy user inputs: class_ids=000000008c010408 num_cmdbufs=2
[152527.163298] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152527.163351] (NULL device *): nvhost_sync_fence_set_name: failed to get fence
[152527.220653] falcon 54340000.vic: pin_array_ids: could not get buf err=-22
[152527.220658] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152527.220672] falcon 54340000.vic: submit_add_gathers: failed to copy user inputs: class_ids=000000008c011058 num_cmdbufs=2
[152527.220675] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152527.220742] (NULL device *): nvhost_sync_fence_set_name: failed to get fence
[152527.294864] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152527.302528] (NULL device *): nvhost_sync_fence_set_name: failed to get fence
[152531.435474] falcon 54340000.vic: pin_array_ids: could not get buf err=-22
[152531.442415] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152531.450040] falcon 54340000.vic: submit_add_gathers: failed to copy user inputs: class_ids=000000009402b868 num_cmdbufs=2
[152531.461120] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152531.468790] (NULL device *): nvhost_sync_fence_set_name: failed to get fence
[152531.496651] falcon 54340000.vic: pin_array_ids: could not get buf err=-22
[152531.503569] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152531.511187] falcon 54340000.vic: submit_add_gathers: failed to copy user inputs: class_ids=000000008c02c3c8 num_cmdbufs=2
[152531.522295] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152531.529951] (NULL device *): nvhost_sync_fence_set_name: failed to get fence
[152531.557475] falcon 54340000.vic: pin_array_ids: could not get buf err=-22
[152531.564498] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152531.572160] falcon 54340000.vic: submit_add_gathers: failed to copy user inputs: class_ids=000000008c02c3c8 num_cmdbufs=2
[152531.583282] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152531.591100] (NULL device *): nvhost_sync_fence_set_name: failed to get fence
[152531.618501] falcon 54340000.vic: pin_array_ids: could not get buf err=-22
[152531.625491] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152531.633095] falcon 54340000.vic: submit_add_gathers: failed to copy user inputs: class_ids=0000000094029088 num_cmdbufs=2
[152531.644148] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152531.651793] (NULL device *): nvhost_sync_fence_set_name: failed to get fence
[152531.678533] falcon 54340000.vic: pin_array_ids: could not get buf err=-22
[152531.685462] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152531.693721] falcon 54340000.vic: submit_add_gathers: failed to copy user inputs: class_ids=0000000094022c28 num_cmdbufs=2
[152531.704807] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152531.712449] (NULL device *): nvhost_sync_fence_set_name: failed to get fence
[152531.739153] falcon 54340000.vic: pin_array_ids: could not get buf err=-22
[152531.746085] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152531.753867] falcon 54340000.vic: submit_add_gathers: failed to copy user inputs: class_ids=000000009402d088 num_cmdbufs=2
[152531.764982] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152531.772766] (NULL device *): nvhost_sync_fence_set_name: failed to get fence
[152531.800198] falcon 54340000.vic: pin_array_ids: could not get buf err=-22
[152531.807132] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152531.814812] falcon 54340000.vic: submit_add_gathers: failed to copy user inputs: class_ids=000000009402c458 num_cmdbufs=2
[152531.825877] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152531.833512] (NULL device *): nvhost_sync_fence_set_name: failed to get fence
[152531.861050] falcon 54340000.vic: pin_array_ids: could not get buf err=-22
[152531.868048] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152531.875649] falcon 54340000.vic: submit_add_gathers: failed to copy user inputs: class_ids=000000008c02c3c8 num_cmdbufs=2
[152531.886761] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152531.894541] (NULL device *): nvhost_sync_fence_set_name: failed to get fence
[152531.922178] falcon 54340000.vic: pin_array_ids: could not get buf err=-22
[152531.929282] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152531.936950] falcon 54340000.vic: submit_add_gathers: failed to copy user inputs: class_ids=0000000094022be8 num_cmdbufs=2
[152531.948434] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152531.956545] (NULL device *): nvhost_sync_fence_set_name: failed to get fence
[152531.984133] falcon 54340000.vic: pin_array_ids: could not get buf err=-22
[152531.991130] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152531.998807] falcon 54340000.vic: submit_add_gathers: failed to copy user inputs: class_ids=0000000094010898 num_cmdbufs=2
[152532.009935] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152532.017743] (NULL device *): nvhost_sync_fence_set_name: failed to get fence
[152532.044936] falcon 54340000.vic: pin_array_ids: could not get buf err=-22
[152532.051946] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152532.059581] falcon 54340000.vic: submit_add_gathers: failed to copy user inputs: class_ids=0000000094022c48 num_cmdbufs=2
[152532.070637] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152532.078263] (NULL device *): nvhost_sync_fence_set_name: failed to get fence
[152532.103764] falcon 54340000.vic: pin_array_ids: could not get buf err=-22
[152532.110675] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152532.118280] falcon 54340000.vic: submit_add_gathers: failed to copy user inputs: class_ids=000000008c02c008 num_cmdbufs=2
[152532.129423] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152532.137121] (NULL device *): nvhost_sync_fence_set_name: failed to get fence
[152532.163940] falcon 54340000.vic: pin_array_ids: could not get buf err=-22
[152532.170867] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152532.178468] falcon 54340000.vic: submit_add_gathers: failed to copy user inputs: class_ids=000000008c02c008 num_cmdbufs=2
[152532.189522] falcon 54340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[152532.197169] (NULL device *): nvhost_sync_fence_set_name: failed to get fence
We have coded a test application and attached. You can download the NVENC.tar.gz and compile it by make CC=aarch64-linux-gnu-g++ in Linux. Of course you shold have the aarch64 cross-compiler. And this test application relays on dynamic library including pthread, v4l2, nvbuf_utils.
NVENC.tar.gz (1.9 MB)
This phenomenon can be easily reproduced by run two or more application attached meanwhile.
Please match the version of samples and system. After installation, you should see the samles in
/usr/src/jetson_multimedia_api
Your system is Jetpack 4.4 and refer to Tegra_Multimedia_API_R32.2.0_aarch64. There can be mismatch in certain header files and it may trigger some issues.
And if possible, we suggest upgrade to latest release Jetpack 4.6.1,
Hi DaneLLL,
I do not know what do you mean by saying “After installation”, install what?
And I can not find /usr/src/jetson_multimedia_api
As for the Multimedia_API version, yes, I use 32.2.0 is not match with system L4T 32.4.3. But I can only find L4T Multimedia API 32.2.3 at https://developer.nvidia.com/embedded/downloads (It was only 32.2.0 when we write our program.)
And there are many devices have deployed, so upgrade to latest is not convenient.
by the way, You can test our application attached. You can easily reproduce it by run two or more application.
So. what should I do now.
The samples have to be installed through SDKManager. Please do the installation and rebuild your application with header files in
/use/arc/jetson_multimedia_api/include
Hi DaneLLL,
We have got the 32.4.3 version of Multimedia API which is consistent with our device system, updated and rebuild our application. But it shows the same fault. I upload the last compressed package of source code. Please help us check it.
God. Please!
NVENC.tar.gz (2.0 MB)
Sorry for the late response, have you managed to get issue resolved or still need the support? Thanks
Just as my last reply, we did not solve this problem. I beg your technician to test our program, please.
The code is similar to 01_video_encode. We would suggest build the sample( nvenc_main.cpp, main.cpp ) by referring to header files and classes in
and so files in
/usr/lib/aarch64-linux-gnu/tegra
to avoid any mismatch in the files. If you can successfully build and run
/usr/src/jetson_multimedia_api/samples/01_video_encode
Your sample should also work fine.
No, my application create a encoder and exit it ceaselessly using thread. The example of 01_video_encode just create once. You should do like me then you can reproduce this bug.
01_video_encode can run stress test:
    -s <loop-count>       Stress test [Default = 1]
Have you enabled it and try?
