Jetson nano.. Wants to reduce the lag while capturing the video from IP cam.
Hello everyone,
I am using jetson Nano for face recognition. Using OpenCV for capturing video.n RTSP protocol for Ip camera. when I run the code on GPU , it works very well…but I wanted to use jetson nano for that…I am new in this field. I have the following question:
  1. if I use GStreamer, will it reduced the lag in capturing frame?
    2)if yes,what is the procedure to use GStreamer in OpenCV?
    this is the code line where i am capturing the video from IP cam.
    cap = cv2.VideoCapture("“rtsp://admin:admin1234@192.168.0.10/cam/realmonitor?
    channel=1&subtype=01&authbasic=YWRtaW46YWRtaW4xMjM0"”)
  2. if no, then what will be the right thing to do reduce that delay…Delay is around 10 sec.
On Jetson Nano, we suggest you use DS4.0.1:
https://devtalk.nvidia.com/default/topic/1063437/deepstream-sdk/announcing-deepstream-sdk-4-0-1/
Here are usecases of running RTSP source:
https://devtalk.nvidia.com/default/topic/1058086/deepstream-sdk/how-to-run-rtp-camera-in-deepstream-on-nano/post/5366807/#5366807
https://devtalk.nvidia.com/default/topic/1058086/deepstream-sdk/how-to-run-rtp-camera-in-deepstream-on-nano/post/5367474/#5367474
Please check and try.
i installed the gstreamer in jetson nano. to check wheather it is properly installed, i played mp4 video using gstreamer.It works well.
I already have code in which i used opencv to capture the frame fron IP cam .It is running well
Instead of that i wants to use gstreamer to capture frame from IP cam…I dont know how to made a url using gstreamer, let me know.
