manifest for nvidia/cuda:10.2-devel-ubuntu18.04 not found: manifest unknown: manifest unknown
Please find Jetson’s CUDA container below:
For example, you can use nvcr.io/nvidia/l4t-cuda:10.2.460-runtime.
i build trtexec with tensorrt in jetson nano
Do you want to build TensorRT with a custom Python version?
If yes, you don’t need to set up a docker environment.
Please follow the steps shared in the below comment:
https://elinux.org/Jetson/L4T/TRT_Customized_Example#TensorRT_Python_Bindings
NO i want to rebuild trtexec tool. I run source code github TensorRT build trtexec on jetson nano. But the library environment is install very difficult, so Im try build docker tensorrt jetson nano to rebuild trtexec
i build successfully
