% sudo nvidia-docker run -it --rm nvcr.io/nvidia/tensorrt:20.03-py3
[sudo] password for ME:
docker: Error response from daemon: OCI runtime create failed: container_linux.go:345: starting container process caused "process_linux.go:430: container init caused \"process_linux.go:413: running prestart hook 1 caused \\\"error running hook: exit status 1, stdout: , stderr: exec command: [/usr/bin/nvidia-container-cli --load-kmods configure --ldconfig=@/sbin/ldconfig.real --device=all --compute --utility --video --require=cuda>=9.0 --pid=22211 /var/lib/docker/overlay2/d1e1dbbc8221597457a4a6b8b9396d4c99941a67b32202726c6f9b2e915ed5ef/merged]\\\\nnvidia-container-cli: mount error: mount operation failed: /usr/src/tensorrt: no such file or directory\\\\n\\\"\"": unknown.
Actually, I have /usr/src/tensorrt on Jetson Nano host.
% ls -ld /usr/src/tensorrt
drwxr-xr-x 5 root root 4096 4月 29 19:53 /usr/src/tensorrt
I’m using nv-jetson-nano-sd-card-image-r32.4.2 as OS image and nvidia-docker versions is:
% sudo nvidia-docker version
NVIDIA Docker: 2.0.3
Client:
Version: 18.09.7
API version: 1.39
Go version: go1.10.1
Git commit: 2d0083d
Built: Fri Aug 16 14:20:24 2019
OS/Arch: linux/arm64
Experimental: false
Server:
Engine:
Version: 18.09.7
API version: 1.39 (minimum version 1.12)
Git commit: 2d0083d
Built: Wed Aug 14 19:41:23 2019
Experimental: false
Any help? Thank you.
