Hi all,
I am following NVIDIA Container Runtime on Jetson · NVIDIA/nvidia-docker Wiki · GitHub and try to run the deviceQuery container on a Jetson Nano node. But when building the container, I got the following error:
$ sudo docker build -t devicequery .
Sending build context to Docker daemon 214.2MB
Step 1/6 : FROM nvcr.io/nvidia/l4t-base:r32.3.1
---> aaaa63e7b12d
Step 2/6 : RUN apt-get update && apt-get install -y --no-install-recommends make g++
---> Running in a9a6681a68c9
OCI runtime create failed: container_linux.go:349: starting container process caused "process_linux.go:449: container init caused \"process_linux.go:432: running prestart hook 1 caused \\\"error running hook: exit status 1, stdout: , stderr: nvidia-container-cli: initialization error: driver error: failed to process request\\\\n\\\"\"": unknown
When I run deviceQuery on the host without container, it can work properly. I search a lot for solution and I found that it might because the driver is not initialized properly:
$ sudo nvidia-container-cli -k -d /dev/tty info
-- WARNING, the following logs are for debugging purposes only --
I0731 03:40:00.306584 31410 nvc.c:282] initializing library context (version=1.2.0, build=d22237acaea94aa5ad5de70aac903534ed598819)
I0731 03:40:00.306735 31410 nvc.c:256] using root /
I0731 03:40:00.306769 31410 nvc.c:257] using ldcache /etc/ld.so.cache
I0731 03:40:00.306789 31410 nvc.c:258] using unprivileged user 65534:65534
I0731 03:40:00.306848 31410 nvc.c:299] attempting to load dxcore to see if we are running under Windows Subsystem for Linux (WSL)
I0731 03:40:00.307075 31410 nvc.c:301] dxcore initialization failed, continuing assuming a non-WSL environment
W0731 03:40:00.307355 31410 nvc.c:172] failed to detect NVIDIA devices
I0731 03:40:00.307634 31416 nvc.c:192] loading kernel module nvidia
E0731 03:40:00.308079 31416 nvc.c:194] could not load kernel module nvidia
I0731 03:40:00.308105 31416 nvc.c:204] loading kernel module nvidia_uvm
E0731 03:40:00.308336 31416 nvc.c:206] could not load kernel module nvidia_uvm
I0731 03:40:00.308356 31416 nvc.c:212] loading kernel module nvidia_modeset
E0731 03:40:00.308589 31416 nvc.c:214] could not load kernel module nvidia_modeset
I0731 03:40:00.309024 31417 driver.c:101] starting driver service
E0731 03:40:00.309567 31417 driver.c:161] could not start driver service: load library failed: libnvidia-ml.so.1: cannot open shared object file: no such file or directory
I0731 03:40:00.309821 31410 driver.c:196] driver service terminated successfully
I have also tried re-installed nvidia-docker2 and reboot the device and docker a couple of times. All of them does not work. The following is my system information:
$ cat /etc/nv_tegra_release
# R32 (release), REVISION: 4.3, GCID: 21589087, BOARD: t210ref, EABI: aarch64, DATE: Fri Jun 26 04:38:25 UTC 2020
$ sudo dpkg -l | grep nvidia
ii libnvidia-container-tools 1.2.0-1 arm64 NVIDIA container runtime library (command-line tools)
ii libnvidia-container0:arm64 0.9.0~beta.1 arm64 NVIDIA container runtime library
ii libnvidia-container1:arm64 1.2.0-1 arm64 NVIDIA container runtime library
ii nvidia-container-csv-cuda 10.2.89-1 arm64 Jetpack CUDA CSV file
ii nvidia-container-csv-cudnn 8.0.0.180-1+cuda10.2 arm64 Jetpack CUDNN CSV file
ii nvidia-container-csv-tensorrt 7.1.3.0-1+cuda10.2 arm64 Jetpack TensorRT CSV file
ii nvidia-container-csv-visionworks 1.6.0.501 arm64 Jetpack VisionWorks CSV file
ii nvidia-container-runtime 3.3.0-1 arm64 NVIDIA container runtime
ii nvidia-container-toolkit 1.2.1-1 arm64 NVIDIA container runtime hook
ii nvidia-docker2 2.4.0-1 all nvidia-docker CLI wrapper
ii nvidia-l4t-3d-core 32.4.3-20200625213809 arm64 NVIDIA GL EGL Package
ii nvidia-l4t-apt-source 32.4.3-20200625213809 arm64 NVIDIA L4T apt source list debian package
ii nvidia-l4t-bootloader 32.4.3-20200709231554 arm64 NVIDIA Bootloader Package
ii nvidia-l4t-camera 32.4.3-20200625213809 arm64 NVIDIA Camera Package
ii nvidia-l4t-configs 32.4.3-20200625213809 arm64 NVIDIA configs debian package
ii nvidia-l4t-core 32.4.3-20200625213809 arm64 NVIDIA Core Package
ii nvidia-l4t-cuda 32.4.3-20200625213809 arm64 NVIDIA CUDA Package
ii nvidia-l4t-firmware 32.4.3-20200625213809 arm64 NVIDIA Firmware Package
ii nvidia-l4t-graphics-demos 32.4.3-20200625213809 arm64 NVIDIA graphics demo applications
ii nvidia-l4t-gstreamer 32.4.3-20200625213809 arm64 NVIDIA GST Application files
ii nvidia-l4t-init 32.4.3-20200625213809 arm64 NVIDIA Init debian package
ii nvidia-l4t-initrd 32.4.3-20200625213809 arm64 NVIDIA initrd debian package
ii nvidia-l4t-jetson-io 32.4.3-20200625213809 arm64 NVIDIA Jetson.IO debian package
ii nvidia-l4t-jetson-multimedia-api 32.4.3-20200625213809 arm64 NVIDIA Jetson Multimedia API is a collection of lower-level APIs that support flexible application development.
ii nvidia-l4t-kernel 4.9.140-tegra-32.4.3-20200625213809 arm64 NVIDIA Kernel Package
ii nvidia-l4t-kernel-dtbs 4.9.140-tegra-32.4.3-20200625213809 arm64 NVIDIA Kernel DTB Package
ii nvidia-l4t-kernel-headers 4.9.140-tegra-32.4.3-20200625213809 arm64 NVIDIA Linux Tegra Kernel Headers Package
ii nvidia-l4t-multimedia 32.4.3-20200625213809 arm64 NVIDIA Multimedia Package
ii nvidia-l4t-multimedia-utils 32.4.3-20200625213809 arm64 NVIDIA Multimedia Package
ii nvidia-l4t-oem-config 32.4.3-20200625213809 arm64 NVIDIA OEM-Config Package
ii nvidia-l4t-tools 32.4.3-20200709231554 arm64 NVIDIA Public Test Tools Package
ii nvidia-l4t-wayland 32.4.3-20200625213809 arm64 NVIDIA Wayland Package
ii nvidia-l4t-weston 32.4.3-20200625213809 arm64 NVIDIA Weston Package
ii nvidia-l4t-x11 32.4.3-20200625213809 arm64 NVIDIA X11 Package
ii nvidia-l4t-xusb-firmware 32.4.3-20200625213809 arm64 NVIDIA USB Firmware Package
$ sudo docker info
Client:
Debug Mode: false
Server:
Containers: 58
Running: 16
Paused: 0
Stopped: 42
Images: 18
Server Version: 19.03.6
Storage Driver: overlay2
Backing Filesystem: extfs
Supports d_type: true
Native Overlay Diff: true
Logging Driver: json-file
Cgroup Driver: cgroupfs
Plugins:
Volume: local
Network: bridge host ipvlan macvlan null overlay
Log: awslogs fluentd gcplogs gelf journald json-file local logentries splunk syslog
Swarm: inactive
Runtimes: nvidia runc
Default Runtime: nvidia
Init Binary: docker-init
containerd version:
runc version:
init version:
Security Options:
seccomp
Profile: default
Kernel Version: 4.9.140-tegra
Operating System: Ubuntu 18.04.4 LTS
OSType: linux
Architecture: aarch64
CPUs: 4
Total Memory: 3.871GiB
Docker Root Dir: /var/lib/docker
Debug Mode: false
Registry: https://index.docker.io/v1/
Labels:
Experimental: false
Insecure Registries:
127.0.0.0/8
Live Restore Enabled: false
Can anyone give me some suggestions about this? Thank you so much!
