I’ve been looking through the forum in an attempt to solve my issue with running l4t docker images:
docker: Error response from daemon: failed to create shim: OCI runtime create failed: container_linux.go:380: starting container process caused: process_linux.go:545: container init caused: Running hook #0:: error running hook: exit status 1, stdout: , stderr: nvidia-container-cli: initialization error: driver error: failed to process request: unknown.
I started off Containers For Deep Learning Frameworks User Guide :: NVIDIA Deep Learning Frameworks Documentation set up the repositories and installed nvidia-docker2 nvidia-container-runtime from here:
https://nvidia.github.io/nvidia-container-runtime/ and https://nvidia.github.io/nvidia-docker/
The contents of nvidia-container-runtime was present in nvidia-docker2 so I only kept nvidia-docker2 (/etc/apt/sources.list.d/nvidia-docker.list)
Pulled nvcr.io/nvidia/l4t-base r32.6.1 from https://catalog.ngc.nvidia.com/
docker and nvidia-docker commands give me the same error:
sudo docker run -it --rm --net=host --runtime nvidia -e DISPLAY=$DISPLAY -v /tmp/.X11-unix/:/tmp/.X11-unix nvcr.io/nvidia/l4t-base:r32.6.1
sudo nvidia-docker run -it --rm --net=host -e DISPLAY=$DISPLAY -v /tmp/.X11-unix/:/tmp/.X11-unix nvcr.io/nvidia/l4t-base:r32.6.1
However, removing --runtime nvidia from docker run puts me at prompt:
sudo docker run -it --rm --net=host -e DISPLAY=$DISPLAY -v /tmp/.X11-unix/:/tmp/.X11-unix nvcr.io/nvidia/l4t-base:r32.6.1
root@tc-xavier:/#
I tried to downgrade docker.io as suggested by another post, but it gave me the same result.
The oldest version, and the one I have installed now:
dpkg -l | grep docker.io
ii docker.io 20.10.2-0ubuntu1~18.04.2 arm64 Linux container runtime
I was thinking that there are some problems with the container runtime but I don’t know how to proceed.
Any suggestions to steer me onto the correct path?
Some information about the system I’m running.
- Installed from SD with JetPack 4.6.
- rootfs is located on m2ssd instead of sd card.
uname -a
Linux tc-xavier 4.9.253-tegra #31 SMP PREEMPT Thu Sep 30 13:31:51 EEST 2021 aarch64 aarch64 aarch64 GNU/Linux
cat /etc/nv_tegra_release
# R32 (release), REVISION: 6.1, GCID: 27863751, BOARD: t186ref, EABI: aarch64, DATE: Mon Jul 26 19:36:31 UTC 2021
cat /etc/os-release
NAME="Ubuntu"
VERSION="18.04.6 LTS (Bionic Beaver)"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu 18.04.6 LTS"
VERSION_ID="18.04"
HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
VERSION_CODENAME=bionic
UBUNTU_CODENAME=bionic
cat /etc/apt/sources.list.d/nvidia-docker.list
deb https://nvidia.github.io/libnvidia-container/stable/ubuntu18.04/$(ARCH) /
#deb https://nvidia.github.io/libnvidia-container/experimental/ubuntu18.04/$(ARCH) /
deb https://nvidia.github.io/nvidia-container-runtime/stable/ubuntu18.04/$(ARCH) /
#deb https://nvidia.github.io/nvidia-container-runtime/experimental/ubuntu18.04/$(ARCH) /
deb https://nvidia.github.io/nvidia-docker/ubuntu18.04/$(ARCH) /
cat /etc/docker/daemon.json
"runtimes": {
"nvidia": {
"path": "nvidia-container-runtime",
"runtimeArgs": []
sudo docker image ls
REPOSITORY TAG IMAGE ID CREATED SIZE
ubuntu latest d5ca7a445605 4 weeks ago 65.6MB
hello-world latest 18e5af790473 7 weeks ago 9.14kB
nvcr.io/nvidia/l4t-base r32.6.1 1735192d3d51 3 months ago 636MB
Thanks in advance :)
