I am trying to use docker in xavier. In the beginning I just install normal docker and use it, it works normally. But with other problem I have here: RTSP stream with openCV: Missing installation? - #8 by jobpasin
I noticed that my docker does not contain /etc/nvidia-container-runtime/host-files-for-container.d/l4t.csv file inside docker and apparently I need to use --runtime nvidia option but it gives error
docker: Error response from daemon: failed to create shim: OCI runtime create failed: container_linux.go:380: starting container process caused: process_linux.go:545: container init caused: Running hook #0:: error running hook: exit status 1, stdout: , stderr: nvidia-container-cli: initialization error: driver error: failed to process request: unknown.
I tried doing what other said in other post but none works for me and I think this problem worth creating a new post, What should I do here?
Some Info
$ dpkg -l | grep docker.io
ii docker.io 20.10.7-0ubuntu5~18.04.3 arm64 Linux container runtime
$ sudo apt-cache show nvidia-jetpack
Package: nvidia-jetpack
Version: 4.6-b199
Architecture: arm64
Maintainer: NVIDIA Corporation
Installed-Size: 194
Depends: nvidia-cuda (= 4.6-b199), nvidia-opencv (= 4.6-b199), nvidia-cudnn8 (= 4.6-b199), nvidia-tensorrt (= 4.6-b199), nvidia-visionworks (= 4.6-b199), nvidia-container (= 4.6-b199), nvidia-vpi (= 4.6-b199), nvidia-l4t-jetson-multimedia-api (>> 32.6-0), nvidia-l4t-jetson-multimedia-api (<< 32.7-0)
Homepage: http://developer.nvidia.com/jetson
Priority: standard
Section: metapackages
Filename: pool/main/n/nvidia-jetpack/nvidia-jetpack_4.6-b199_arm64.deb
SHA256: d67b85293cade45d81dcafebd46c70a97a0b0d1379ca48aaa79d70d8ba99ddf8
SHA1: 74d9cbdfe9af52baa667e321749b9771101fc6de
MD5sum: cd1b3a0b651cd214b15fa76f6b5af2cd
Description: NVIDIA Jetpack Meta Package
Description-md5: ad1462289bdbc54909ae109d1d32c0a8
Version: 4.6-b197
Architecture: arm64
Installed-Size: 194
Depends: nvidia-cuda (= 4.6-b197), nvidia-opencv (= 4.6-b197), nvidia-cudnn8 (= 4.6-b197), nvidia-tensorrt (= 4.6-b197), nvidia-visionworks (= 4.6-b197), nvidia-container (= 4.6-b197), nvidia-vpi (= 4.6-b197), nvidia-l4t-jetson-multimedia-api (>> 32.6-0), nvidia-l4t-jetson-multimedia-api (<< 32.7-0)
Priority: standard
Filename: pool/main/n/nvidia-jetpack/nvidia-jetpack_4.6-b197_arm64.deb
SHA256: acec83ad0c1ef05caf9b8ccc6a975c4fb2a7f7830cbe63bbcf7b196a6c1f350e
SHA1: 3e11456cf0ec6b3a40d81b80ca1e14cebafa65ff
MD5sum: 72b2b7b280793bd4abdabe0d38b08535
(Not sure why they show two jetpack version here]
Also, I moved my docker image location to SD card because the memory of xavier is already full, hopefully this is not the source of the problem.
