datlt
October 12, 2021, 8:35am
#1
I have a Jetson AGX, and I want to run docker image nvcr.io/nvidia/l4t-base:r32.6.1
. I referenced many tutorials they told me that I need to install nvidia-container-runtime
All commands I used to install nvidia-container-runtime
listed below:
curl -s -L https://nvidia.github.io/nvidia-docker/gpgkey | sudo apt-key add -
distribution=$(. /etc/os-release;echo $ID$VERSION_ID)
curl -s -L https://nvidia.github.io/nvidia-docker/$distribution/nvidia-docker.list | sudo tee /etc/apt/sources.list.d/nvidia-docker.list
sudo apt-get update
sudo apt-get install nvidia-docker2 -y
In addition, I modified the /etc/docker/daemon.json
with content:
"runtimes": {
"nvidia": {
"path": "/usr/bin/nvidia-container-runtime",
"runtimeArgs": []
"default-runtime": "nvidia"
After all, I restart docker daemon:
sudo systemctl restart docker
All above steps I did on other Jetson NX and docker work fine, but when i run docker image l4t-base:r32.6.1
on my Jetson AGX with interactive mode
sudo docker run -it --rm --net=host --runtime nvidia -e DISPLAY=$DISPLAY -v /tmp/.X11-unix/:/tmp/.X11-unix nvcr.io/nvidia/l4t-base:r32.6.1
I received error:
docker: Error response from daemon: OCI runtime create failed: container_linux.go:380: starting container process caused: process_linux.go:545: container init caused: Running hook #0:: error running hook: exit status 1, stdout: , stderr: nvidia-container-cli: initialization error: driver error: failed to process request: unknown.
vizgard@vizgard:~$ sudo dpkg --get-selections | grep nvidia
libnvidia-container-tools install
libnvidia-container1:arm64 install
nvidia-container-runtime install
nvidia-container-toolkit install
nvidia-docker2 install
nvidia-l4t-3d-core install
nvidia-l4t-apt-source install
nvidia-l4t-bootloader install
nvidia-l4t-camera install
nvidia-l4t-configs install
nvidia-l4t-core install
nvidia-l4t-cuda install
nvidia-l4t-firmware install
nvidia-l4t-graphics-demos install
nvidia-l4t-gstreamer install
nvidia-l4t-init install
nvidia-l4t-initrd install
nvidia-l4t-jetson-io install
nvidia-l4t-kernel install
nvidia-l4t-kernel-dtbs install
nvidia-l4t-kernel-headers install
nvidia-l4t-multimedia install
nvidia-l4t-multimedia-utils install
nvidia-l4t-oem-config install
nvidia-l4t-tools install
nvidia-l4t-wayland install
nvidia-l4t-weston install
nvidia-l4t-x11 install
nvidia-l4t-xusb-firmware install
vizgard@vizgard:~$ sudo docker info | grep nvidia
Runtimes: io.containerd.runc.v2 io.containerd.runtime.v1.linux nvidia runc
Default Runtime: nvidia
The container requires r32.6.1 OS but you are using r32.5.0 which is incompatible.
Please upgrade your Xavier with JetPack4.6 or use nvcr.io/nvidia/l4t-base:r32.5.0
instead.
datlt
October 12, 2021, 9:10am
#5
I downloaded nvcr.io/nvidia/l4t-base:r32.5.0
and run, but the same error with r32.6.1
vizgard@vizgard:~$ docker run -it --rm --net=host --runtime nvidia -e DISPLAY=$DISPLAY -v /tmp/.X11-unix/:/tmp/.X11-unix nvcr.io/nvidia/l4t-base:r32.5.0
Unable to find image 'nvcr.io/nvidia/l4t-base:r32.5.0' locally
r32.5.0: Pulling from nvidia/l4t-base
5000a6c32c5a: Pull complete
8e855b69096a: Pull complete
8db8dbbd4bb9: Pull complete
833dc3235950: Pull complete
f79d264135a3: Pull complete
1c40f77bb35b: Pull complete
1990ecf0bfb7: Pull complete
c8ffbfd7f0aa: Pull complete
ba785779122a: Pull complete
024ce79b6790: Pull complete
9b09da3b5483: Pull complete
17f974a43cf9: Pull complete
211b56b73ff1: Pull complete
78aca4be1f3b: Pull complete
95f34310bbda: Pull complete
678c9d1557e9: Pull complete
ec17ad7cab01: Pull complete
08fb1eee5328: Pull complete
Digest: sha256:c7207a13da6054c738b530aad93e8c620182db85eb7fbb40b103757145e8b5f4
Status: Downloaded newer image for nvcr.io/nvidia/l4t-base:r32.5.0
alex15
October 13, 2021, 5:00am
#6
Hi @AastaLLL thank you for your assistance so far. Can you urgently let us know your thoughts on why it still doesn’t work after changing to a compatible version?
datlt
October 15, 2021, 7:50am
#7
@AastaLLL , I reinstall AGX with r32.6.1
OS, and no more error driver
notification. But I ran sudo apt-get install nvidia-docker2 -y
again, AGX error driver
again. Do you have a way restore the original state of jetpack, because I cannot reinstall OS again?
alex15
October 16, 2021, 11:45am
#8
@alanz do you have any thoughts on datlt’s last comment?
alanz
October 16, 2021, 12:23pm
#9
You don’t need to install the docker runtime, It’s already there when you flashed the Xavier with JP4.6.1. Here is the default components lists.
xavier@xavier-desktop:~$ sudo dpkg --get-selections | grep nvidia
libnvidia-container0:arm64 install
nvidia-container-csv-cuda install
nvidia-container-csv-cudnn install
nvidia-container-csv-tensorrt install
nvidia-l4t-gputools install
nvidia-l4t-jetson-multimedia-api install
nvidia-l4t-libvulkan install
I don’t see any issue.
xavier@xavier-desktop:~$ sudo docker pull nvcr.io/nvidia/l4t-base:r32.6.1
r32.6.1: Pulling from nvidia/l4t-base
e47a8a86d66c: Pull complete
bdce3430dad6: Pull complete
c26a6b81c746: Pull complete
a70635e646de: Pull complete
24cbe60e3161: Pull complete
c7f64cc97a39: Pull complete
8777adb92eda: Pull complete
542a24b3572f: Pull complete
3d5ade2b8849: Pull complete
3e865584f789: Pull complete
4811af6cacf1: Pull complete
db645757aac7: Pull complete
0105dc23dc93: Pull complete
c8aff3baf097: Pull complete
5f50b3e38480: Pull complete
b5418d85b074: Pull complete
Digest: sha256:66e8d2e16d4e0745d9d24e40271511dfb287bd4718b4d8a68c177a8981decb16
Status: Downloaded newer image for nvcr.io/nvidia/l4t-base:r32.6.1
xavier@xavier-desktop:~$ sudo dpkg --get-selections | grep nvidia^C
xavier@xavier-desktop:~$ sudo docker run -it --rm --net=host --runtime nvidia -e DISPLAY=$DISPLAY -v /tmp/.X11-unix/:/tmp/.X11-unix nvcr.io/nvidia/l4t-base:r32.6.1
root@xavier-desktop:/#
root@xavier-desktop:/# ls
bin boot dev dst etc home lib media mnt opt proc root run sbin srv sys tmp usr var
alex15
November 1, 2021, 3:10pm
#11
Hi @alanz , we got this fully up and running in the end so thank you for your help. There was one issue, however. In order to use docker, we had to install the entire SDK Toolkit so that the container components were installed. This used up valuable space which was probably unnecessary as our docker image contained all the libraries we would need. When datlt tried to install just nvidia container components it didn’t appear to install.
Next time, I would like to just flash the jetson, install whatever is required to allow docker images, and then install the docker image. How do we install what is required after the basic flashing has completed?
alanz
November 2, 2021, 12:45am
#12
Pls file another topic to tracking this.
