tnaduc
1
I just got a new Jetson AGX Xavier board and tried to start a basic ml container from NGC, however, it couldn’t run.
sudo docker run -it --rm --runtime nvidia --network host nvcr.io/nvidia/l4t-ml:r32.4.4-py3
Unable to find image 'nvcr.io/nvidia/l4t-ml:r32.4.4-py3' locally
r32.4.4-py3: Pulling from nvidia/l4t-ml
e74fe6ef6bd6: Already exists
7dcdd1c8f1d2: Already exists
148ea20d31e0: Already exists
fbc4cd4d050b: Already exists
a21b0b3d8206: Already exists
4ba0c94f9855: Already exists
6fb19c1062d0: Already exists
84ff17ad4b18: Already exists
5ac903fdc4a8: Already exists
ecf00917e120: Already exists
30d000a9cd22: Already exists
a26b515ffe8f: Already exists
a199cb2dd71e: Already exists
c4f4e0f882d3: Already exists
3e956de9ea4b: Already exists
e26b78d1aaed: Already exists
ac42496d0bc2: Already exists
7db2983f5802: Already exists
7caf5120c657: Pull complete
515bee6e4e21: Pull complete
665a812071a4: Pull complete
fa149c1c8827: Pull complete
f159a33bd92b: Pull complete
9d574cc5f4bd: Pull complete
9b6f3604c42b: Pull complete
8999d5401777: Pull complete
445213ad4422: Pull complete
fd4f94a64928: Pull complete
bf481d5e0a20: Pull complete
d9d3a4f227ec: Pull complete
871ab20f86fa: Pull complete
42382b377b81: Pull complete
355caf84fb48: Pull complete
08daa9581bc5: Pull complete
f31b8c487ed8: Pull complete
Digest: sha256:c3c1ebea04bbb428e50480b52c06af03b7172fbda1d5309c60f735f9e0797663
Status: Downloaded newer image for nvcr.io/nvidia/l4t-ml:r32.4.4-py3
docker: Error response from daemon: OCI runtime create failed: container_linux.go:367: starting container process caused: process_linux.go:495: container init caused: Running hook #0:: error running hook: exit status 1, stdout: , stderr: nvidia-container-cli: initialization error: driver error: failed to process request: unknown.
Here is basic info about the board:
- NVIDIA Jetson AGX Xavier [16GB]
* Jetpack 4.4 [L4T 32.4.3]
* NV Power Mode: MODE_30W_ALL - Type: 3
* jetson_stats.service: active
- Libraries:
* CUDA: 10.2.89
* cuDNN: 8.0.0.180
* TensorRT: 7.1.3.0
* Visionworks: 1.6.0.501
* OpenCV: 4.1.1 compiled CUDA: NO
* VPI: 0.3.7
* Vulkan: 1.2.70
Docker:
Client: Docker Engine - Community
Version: 20.10.5
API version: 1.41
Go version: go1.13.15
Git commit: 55c4c88
Built: Tue Mar 2 20:18:54 2021
OS/Arch: linux/arm64
Context: default
Experimental: true
Server: Docker Engine - Community
Engine:
Version: 20.10.5
API version: 1.41 (minimum version 1.12)
Git commit: 363e9a8
Built: Tue Mar 2 20:16:53 2021
Experimental: false
containerd:
Version: 1.4.4
GitCommit: 05f951a3781f4f2c1911b05e61c160e9c30eaa8e
runc:
Version: 1.0.0-rc93
GitCommit: 12644e614e25b05da6fd08a38ffa0cfe1903fdec
docker-init:
Version: 0.19.0
GitCommit: de40ad0
Docker runtime:
cat /etc/docker/daemon.json
"runtimes": {
"nvidia": {
"path": "nvidia-container-runtime",
"runtimeArgs": []
It runs perfectly fine with my Jetson nano and Jetson Tx2
Your environment is r32.4.3.
Could you give below container a try?
$ sudo docker run -it --rm --runtime nvidia --network host nvcr.io/nvidia/l4t-ml:r32.4.3-py3
Thanks @AastaLLL for looking into this. I just have a quick try, it still returned the same error:
Unable to find image 'nvcr.io/nvidia/l4t-ml:r32.4.3-py3' locally
r32.4.3-py3: Pulling from nvidia/l4t-ml
c796196a5194: Pulling fs layer
9f1f9f625de3: Pulling fs layer
692bb77a7fc0: Pulling fs layer
7c6fea64666e: Pulling fs layer
2e07510b3b6f: Pulling fs layer
f3cef679c558: Pull complete
01067c06de71: Pull complete
607a871f53a8: Pull complete
77c272c815a4: Pull complete
d6e9ae6c556e: Pull complete
6c31b14f8325: Pull complete
da342f04dbe2: Pull complete
bc1f73093866: Pull complete
801ec5982390: Pull complete
20f4f4b58bf1: Pull complete
998db3ceb21f: Pull complete
8f6eafd35194: Pull complete
c3cf45f768ae: Pull complete
7b3abe05cce9: Pull complete
8977efcd7cb6: Pull complete
5fa352cd64d8: Pull complete
f858db5ee73c: Pull complete
c25066acf55c: Pull complete
cee7c26afb29: Pull complete
e95be1d362be: Extracting [==================================================>] 307MB/307MB
e95be1d362be: Pull complete
493dda69c3c8: Pull complete
8e6fc188d98a: Pull complete
8ca5b0b1221c: Pull complete
e927bc5b62ba: Pull complete
c62d62d4b6d8: Pull complete
cd1b219d0452: Pull complete
3604ec2ef5ba: Pull complete
48514e1a3709: Pull complete
f0491a7196f1: Pull complete
b68bcdfc7c06: Pull complete
356c673f0194: Pull complete
Digest: sha256:61de72a4d5c34841c2135004f52b6813101610a4829817d93b8736298cc9ac39
Status: Downloaded newer image for nvcr.io/nvidia/l4t-ml:r32.4.3-py3
Hello @tnaduc ,
Can you try it with newer image?
sudo docker run -it --rm --runtime nvidia --network host nvcr.io/nvidia/l4t-ml:r32.5.0-py3
Regards.
Hi @ozguryildiz ,
Thank you for your advice, I tried it, still the same result
[sudo] password for mic-730ai:
Unable to find image 'nvcr.io/nvidia/l4t-ml:r32.5.0-py3' locally
r32.5.0-py3: Pulling from nvidia/l4t-ml
5000a6c32c5a: Pull complete
8e855b69096a: Pull complete
8db8dbbd4bb9: Pull complete
833dc3235950: Pull complete
f79d264135a3: Pull complete
1c40f77bb35b: Pull complete
1990ecf0bfb7: Pull complete
c8ffbfd7f0aa: Pull complete
ba785779122a: Pull complete
024ce79b6790: Pull complete
9b09da3b5483: Pull complete
17f974a43cf9: Pull complete
211b56b73ff1: Pull complete
78aca4be1f3b: Pull complete
95f34310bbda: Pull complete
678c9d1557e9: Pull complete
ec17ad7cab01: Pull complete
08fb1eee5328: Pull complete
df804e245232: Pull complete
4f9a01a0e955: Pull complete
a44515425a95: Pull complete
cf055aaf10ad: Pull complete
844538a014b9: Pull complete
159036d408be: Pull complete
ae321b977e2f: Pull complete
ae4d2ced71ce: Pull complete
1bc11ebf8522: Pull complete
ef6ff4fc67ed: Pull complete
3b45df8b8d80: Pull complete
a1a094c74107: Pull complete
7400833e9fab: Pull complete
21608f9f63e2: Pull complete
50b80108db64: Pull complete
800ad6d6d249: Pull complete
a5297af96097: Pull complete
5d3a862a0013: Pull complete
418524dee780: Pull complete
Digest: sha256:af8155d948946e76fb398a93a726ee4e4f06a69574284a8bc8929f0731efdc61
Status: Downloaded newer image for nvcr.io/nvidia/l4t-ml:r32.5.0-py3
The same for the lt4 base:
sudo docker run -it --rm --net=host --runtime nvidia -e DISPLAY=$DISPLAY -v /tmp/.X11-unix/:/tmp/.X11-unix nvcr.io/nvidia/l4t-base:r32.4.3
Hello @tnaduc ,
Please type the below command and check what it happens.
sudo apt-get update && sudo apt-get install -y nvidia-container-toolkit
Hope it works.
tnaduc
8
Hi @ozguryildiz , thank you.
Tried that and still having same outcome. :(
