Jetson nano doesnt work with docker
I just bought the jetson-nano developer kit and im following this tutorial on how to get started
Its this part where you set up your docker however when following those steps i run into this error:
docker: Error response from daemon: failed to create shim: OCI runtime create failed: container_linux.go:380: starting container process caused: error adding seccomp filter rule for syscall clone3: permission denied: unknown.
So apperently this is caused by the wrong docker version
How can i downgrade the docker version to make this work?
I came across this fix but this genious doesnt explain how to downgrade docker nor does his approach work for me
Doing this:
sudo apt install ./docker.io_19.03.6-0ubuntu1_18.04.3_arm64.deb
Reading package lists... Done
E: Unsupported file ./docker.io_19.03.6-0ubuntu1_18.04.3_arm64.deb given on commandline
is giving me errors.
So please let me know how to make this work and maybe someon from nvidia could provide a fix in the documentation for that:
Cause i dont understand why i have to look for a fix instead of invidia just making this work out the box:
Im frustated already with my jetson nano and i havent even started using it.
Welcome to the NVIDIA Developer forums! I am moving your topic to the Jetson Nano category for better visibility. Someone from the support team should be able to assist you there.
Best,
Tom K
Could you check which OS version do you use?
This information can be retrieved via the following command:
$ cat /etc/nv_tegra_release
Then launch the container with the corresponding version.
For example, we are using JetPack 4.6 which is r32.6.1.
# R32 (release), REVISION: 6.1, GCID: 27863751, BOARD: t186ref, EABI: aarch64, DATE: Mon Jul 26 19:36:31 UTC 2021
Then the command for our environment should be :
# create a reusable script
echo "sudo docker run --runtime nvidia -it --rm --network host \
    --volume ~/nvdli-data:/nvdli-nano/data \
    --device /dev/video0 \
    nvcr.io/nvidia/dli/dli-nano-ai:v2.0.1-r32.6.1" > docker_dli_run.sh
# make the script executable
chmod +x docker_dli_run.sh
# run the script
./docker_dli_run.sh
I get this error
I got the same error yesterday.
I was able to run the container without the nvidia runtime tag.
I couldn’t find any solution. I reflashed my memory card and now it works.
check if it works with this
Hi, @user92441 and @user75788
As polok mentioned, there is a known issue that will cause OCI runtime create failed error.
Have you tried the workaround shared in the above link?
If not, would you mind giving it a try?
The problem come from updating docker , ubuntu update docker for 20.04 , and it compatible with your docker container. You should downgrade it.
Solution:
distribution=$(. /etc/os-release;echo $ID$VERSION_ID) \
   && curl -s -L https://nvidia.github.io/nvidia-docker/gpgkey | sudo apt-key add - \
   && curl -s -L https://nvidia.github.io/nvidia-docker/$distribution/nvidia-docker.list | sudo tee /etc/apt/sources.list.d/nvidia-docker.list
sudo apt-get update
sudo apt-get install nvidia-docker2=2.8.0-1
