I’m doing the AI training and do:
sudo docker run --runtime nvidia -it --rm --network host --volume ~/nvdli-data:/nvdli-nano/data --device /dev/video0 nvcr.io/nvidia/dli/dli-nano-ai:v2.0.1-r32.6.1
and get the reply:
docker: Error response from daemon: failed to create shim: OCI runtime create failed: container_linux.go:380: starting container process caused: error adding seccomp filter rule for syscall clone3: permission denied: unknown.
I’m new to Jetson Nano. Can somebody help?
Sorry that this is a known issue due to the docker upgrade.
Please find a workaround in the below comment:
I did it. but how do I run the docker now?
The previous command on NVIDIA site is:
–volume ~/nvdli-data:/nvdli-nano/data
–device /dev/video0
Yes, after applying the workaround, please run the original command to see if it works.
Please let us know the following.
