Docker: Error response from daemon: failed to create shim: OCI runtime create failed: container_linux.go:380: starting container process caused: error
Hi, I just got my Jetson Nano 2GB Dev kit and I started following along with the course called “Getting started with AI on Jetson Nano” then ran into an issue. I got to the part where you make the data directory then run the Docker container and when I run the Docker container I get this Error.
docker: Error response from daemon: failed to create shim: OCI runtime create failed: container_linux.go:380: starting container process caused: error adding seccomp filter rule for syscall clone3: permission denied: unknown.
I have looked this up and I can’t find much about it and it’s very frustrating.
Here is the terminal has shown me leading up to it,
        evan@evan-desktop:~$ mkdir -p ~/nvdli-data        evan@evan-desktop:~$ ls        Desktop  Documents  Downloads  examples.desktop  Music  nvdli-data  Pictures  Public  Templates  Videos        evan@evan-desktop:~$ echo "sudo docker run --runtime nvidia -it --rm --network host \        >     --volume ~/nvdli-data:/nvdli-nano/data \        >     --device /dev/video0 \        >     nvcr.io/nvidia/dli/dli-nano-ai:v2.0.1-r32.6.1" > docker_dli_run.sh        evan@evan-desktop:~$        evan@evan-desktop:~$ ./docker_dli_run.sh        -bash: ./docker_dli_run.sh: Permission denied        evan@evan-desktop:~$ chmod +x docker_dli_run.sh        evan@evan-desktop:~$ ./docker_dli_run.sh        [sudo] password for evan:        Unable to find image 'nvcr.io/nvidia/dli/dli-nano-ai:v2.0.1-r32.6.1' locally        v2.0.1-r32.6.1: Pulling from nvidia/dli/dli-nano-ai        b9bb7af7248f: Pull complete        334a570c08f5: Pull complete        c8bd4a89e71c: Pull complete        0a8ce4f08307: Pull complete        2e163bfa50fc: Pull complete        8d6d8c86a148: Pull complete        b483bad8509f: Pull complete        8da3c6b29858: Pull complete        a3e94453e320: Pull complete        40ad1f92affd: Pull complete        8ac6e2f9e2a0: Pull complete        cc932e62bbab: Pull complete        d77841654f58: Pull complete        2bb42f0b6424: Pull complete        954e18eab77a: Pull complete        facc6f8bcc9b: Pull complete        78d4b308041f: Pull complete        44f9a409dddf: Pull complete        dc19965f7530: Pull complete        73f02f5e17e7: Pull complete        de4b3c1acb9b: Pull complete        6c2b9910111b: Pull complete        1cb44dee771f: Pull complete        bf00de567184: Pull complete        b73a0bf964ae: Pull complete        579ce47ae238: Pull complete        2262c28018a2: Pull complete        177925b6dcf7: Pull complete        7b4747fe9173: Pull complete        02a1844af779: Pull complete        f8db2318d17d: Pull complete        0de061a3a027: Pull complete        061f9fe486d4: Pull complete        577717fda284: Pull complete        99eb42711cda: Pull complete        f4b5c276e151: Pull complete        8c40ad4db82e: Pull complete        0f75432e814b: Pull complete        e7d8e736231c: Pull complete        Digest: sha256:7d77446f42a89a1d9885c886ffc2a67e557c5c08665f3e4ee02e9f2d6d0d799b        Status: Downloaded newer image for nvcr.io/nvidia/dli/dli-nano-ai:v2.0.1-r32.6.1        docker: Error response from daemon: failed to create shim: OCI runtime create failed: container_linux.go:380: starting container process caused: error adding seccomp filter rule for syscall clone3: permission denied: unknown.
Could you share which JetPack version do you use?
Please note that you will need to launch the container with the same OS version.
For example, JetPack 4.6 use r32.6.1.
So please use the nvcr.io/nvidia/dli/dli-nano-ai:v2.0.1-r32.6.1 container.
I downloaded the 4.6 and I tried that and it didnt work this is how I put it in.
then
./docker_dli_run.sh
I received
hi i had the same problem, i fixedd it with the solution from jgardynik in this link
Docker fails to create container after upgrading docker on Jetpack 4.9 · Issue #108 · dusty-nv/jetson-containers (github.com)
hope it work for you
edit: Docker isn’t working after apt upgrade - Jetson & Embedded Systems / Jetson Nano - NVIDIA Developer Forums
The second link fixed it all. Thanks for the help!!! This is a great community, thought I was going to be waiting for a couple of days for an answer.
