I’m using a jetson nano 2 gb and I tried to run the ./docker_dli_run.sh. 1 day ago I got any problems but since I trunned on today to execute it with the following command:
echo "sudo docker run --runtime nvidia -it --rm --network host \
--volume ~/nvdli-data:/nvdli-nano/data \
--device /dev/video0 \
nvcr.io/nvidia/dli/dli-nano-ai:v2.0.1-r32.4.4" > docker_dli_run.sh
I get Denied Permission issue that gets solved with:
chmod +x docker_dli_run.sh
now, it still not running when I execute :
./docker_dli_run.sh
Each time, I’m getting :
docker: Error response from daemon: OCI runtime create failed: container_linux.go:349: starting container process caused "process_linux.go:449: container init caused \"process_linux.go:432: running prestart hook 0 caused \\\"error running hook: exit status 1, stdout: , stderr: exec command: [/usr/bin/nvidia-container-cli --load-kmods configure --ldconfig=@/sbin/ldconfig.real --device=all --compute --compat32 --graphics --utility --video --display --pid=6884 /var/lib/docker/overlay2/dd8323a59ce054f3d8dca1ee77973773b92a2be247af38170720d0efcf1884aa/merged]\\\\nnvidia-container-cli: mount error: file creation failed: /var/lib/docker/overlay2/dd8323a59ce054f3d8dca1ee77973773b92a2be247af38170720d0efcf1884aa/merged/usr/lib/aarch64-linux-gnu/libnvidia-fatbinaryloader.so.440.18: file exists\\\\n\\\"\"": unknown.
