8th install attempt
FROM SCRATCH. setup the GUI. booted.
connected SSH to nano,
mkdir -p ~/nvdli-data
echo “sudo docker run --runtime nvidia -it --rm --network host
–volume ~/nvdli-data:/nvdli-nano/data
–device /dev/video0
nvcr.io/nvidia/dli/dli-nano-ai:v2.0.1-r32.4.4” > docker_dli_run.sh
chmod +x docker_dli_run.sh
o:~$ ./docker_dli_run.sh
docker: Error response from daemon: OCI runtime create failed: container_linux.go:349: starting container process caused “process_linux.go:449: container init caused "process_linux.go:432: running prestart hook 0 caused \"error running hook: exit status 1, stdout: , stderr: exec command: [/usr/bin/nvidia-container-cli --load-kmods configure --ldconfig=@/sbin/ldconfig.real --device=all --compute --compat32 --graphics --utility --video --display --pid=9844 /var/lib/docker/overlay2/4b9b160fe9d2630fdea0999ce1759b4235b9950b10c9124086d8adbb2fc25fb8/merged]\\nnvidia-container-cli: mount error: file creation failed: /var/lib/docker/overlay2/4b9b160fe9d2630fdea0999ce1759b4235b9950b10c9124086d8adbb2fc25fb8/merged/usr/lib/aarch64-linux-gnu/libnvidia-fatbinaryloader.so.440.18: file exists\\n\""”: unknown.
o:~$ sudo ./docker_dli_run.sh
docker: Error response from daemon: OCI runtime create failed: container_linux.go:349: starting container process caused “process_linux.go:449: container init caused "process_linux.go:432: running prestart hook 0 caused \"error running hook: exit status 1, stdout: , stderr: exec command: [/usr/bin/nvidia-container-cli --load-kmods configure --ldconfig=@/sbin/ldconfig.real --device=all --compute --compat32 --graphics --utility --video --display --pid=9989 /var/lib/docker/overlay2/14476163dfc9cab125e310ebdb8c1a05b17ddd3979c0f421834180e8d6413a85/merged]\\nnvidia-container-cli: mount error: file creation failed: /var/lib/docker/overlay2/14476163dfc9cab125e310ebdb8c1a05b17ddd3979c0f421834180e8d6413a85/merged/usr/lib/aarch64-linux-gnu/libnvidia-fatbinaryloader.so.440.18: file exists\\n\""”: unknown.
