Jetson NX kernel 4.9 kernel compilation shows "Path is not clean" after modifying tegra_defconfig
I have added a new driver for the IMX568 and want to compile it into the kernel. Currently, I’m facing an issue:
No matter if I add the IMX568 driver in tegra_defconfig or menuconfig, the kernel compilation always fails with the following error message (as shown in the screenshot). Even after executing make mrproper and recompiling, the error persists. If I do not modify the configuration, the compilation passes without issues. Why is this happening? Are there any changes I might have missed?
hello 914039686,
Orin NX it should not based-on kernel-4.9, may I double check which platform you’re working with?
BTW, please see-also developer gudie, Kernel Customization.
I am using Xavier NX with JetPack 32.4.3. The kernel version 4.9 is quite old. Meanwhile, I have referred to the provided kernel compilation instructions.
hello 914039686,
let me move this topic to Xavier NX category.
it looks like some prerequisites utility has missed. may I know what’s your ubuntu version.
please gather the complete building messages as single text file, and sharing it here for reference.
besides, JP-4.4 (l4t-r32.4.3) is quite old. if that’s possible, please try moving forward to the latest release version for verification.
