Jetson Orin Deepstream 6.3 nvll_osd_draw_rectangles with MODE_GPU
Hi guys I need small help with drawing OSD on jetson orin
thanks for any help
NVIDIA Jetson Orin Nano Engineering Reference Developer Kit Super
R35 (release), REVISION: 6.4, GCID: 43803471, BOARD: t186ref, EABI: aarch64, DATE: Tue Jan 27 08:01:21 UTC 2026
deepstream-app version 6.3.0
DeepStreamSDK 6.3.0
CUDA Driver Version: 11.4
CUDA Runtime Version: 11.4
TensorRT Version: 8.5
cuDNN Version: 8.6
libNVWarp360 Version: 2.0.1d3
CUDA device count: 1
Device 0: Orin
SMs: 8
Memory: 7451 MB
what I try to do
    // init
    cudaError_t CUerr = cudaSuccess;
    CUerr = cudaSetDevice(0); // TODO move to params
    if (CUerr != cudaSuccess) {
        throw std::runtime_error("cudaSetDevice failed");
    _nvosdContext = nvll_osd_create_context();
  // draw
    CUerr = cudaFree(0);
        throw std::runtime_error("cudaFree failed");
    NvOSD_FrameRectParams frame_rect_params;
    memset(&frame_rect_params, 0, sizeof(frame_rect_params));
    frame_rect_params.mode = MODE_GPU;  // in case MODE_CPU all work perfect
    frame_rect_params.buf_ptr = nullptr;
    frame_rect_params.num_rects = _arrRectCount;
    frame_rect_params.rect_params_list = _arrRect;
    if (NvBufSurfaceFromFd(dma_buf_fd, (void**)&frame_rect_params.surf) != 0) {
        throw std::runtime_error("Failed to get NvBufSurface from FD");
    if (NvBufSurfaceMap(frame_rect_params.surf, -1, -1, NVBUF_MAP_READ_WRITE)) {
        throw std::runtime_error("Failed NvBufSurfaceMap");
    if (NvBufSurfaceSyncForDevice(frame_rect_params.surf, -1, -1)) {
        throw std::runtime_error("Failed NvBufSurfaceSyncForDevice");
    int res = nvll_osd_draw_rectangles(_nvosdContext, &frame_rect_params);
    if (NvBufSurfaceSyncForCpu(frame_rect_params.surf, -1, -1)) {
        throw std::runtime_error("Failed NvBufSurfaceSyncForCpu");
    if (NvBufSurfaceUnMap(frame_rect_params.surf, -1, -1)) {
    if (res != 0) {
        fprintf(stderr, "OSD Apply failed with error: %d\n", res);
no errors appear but still no rectangles on frame
and all fine with MODE_CPU so all setup looks fine
according to this post I add nvll_osd_apply but still nothing
    NvOSDCtxHandle nvdsosd_context = nvll_osd_create_context ();
    int res = nvll_osd_draw_rectangles(nvdsosd_context, &frame_rect_params);
    if (res == 0) {
        res = nvll_osd_apply(nvdsosd_context, nullptr, frame_rect_params.surf);
    nvll_osd_destroy_context(nvdsosd_context);
added nvll_osd_set_params during init phase
