I am using deepstream-app with 4 streams of video.
I like to plot rectangles to highlight a few region of interests on images from 4 video streams.
How can I plot? Any sample for that?
• DeepStream Version
• TensorRT Version
Xavier
5.1
R32 (release), REVISION: 4.3, GCID: 21589087, BOARD: t186ref, EABI: aarch64, DATE: Fri Jun 26 04:34:27 UTC 2020
• TensorRT Version
latest
10.2
Plot using gstdsexample is working for me.
Added gsddsexample to deepstream-app in config file and I can plot on cvmat inside the file.
I think you can just add the rectangle params and osd will do the draw work, refer NVIDIA DeepStream SDK API Reference: Main Page
That is good idea. How can I add rect_params to nvdsosd?
In the following code,
if (batch_meta)
full_obj_meta_list = batch_meta->obj_meta_pool->full_list;
NvDsObjectMeta *object_meta = NULL;
for (l = full_obj_meta_list; l != NULL; l = l->next) {
object_meta = (NvDsObjectMeta *) (l->data);
if (nvdsosd->draw_bbox) {
nvdsosd->rect_params[rect_cnt] = object_meta->rect_params;
#ifdef PLATFORM_TEGRA
/* In case of hardware blending, values set in hw-blend-color-attr
should be considered as rect bg color values*/
if (nvdsosd->nvdsosd_mode == MODE_HW && nvdsosd->hw_blend) {
for (idx = 0; idx < nvdsosd->num_class_entries; idx++) {
if (nvdsosd->color_info[idx].id == object_meta->class_id) {
nvdsosd->rect_params[rect_cnt].color_id = idx;
nvdsosd->rect_params[rect_cnt].has_bg_color = TRUE;
nvdsosd->rect_params[rect_cnt].bg_color.red =
nvdsosd->color_info[idx].color.red;
nvdsosd->rect_params[rect_cnt].bg_color.blue =
nvdsosd->color_info[idx].color.blue;
nvdsosd->rect_params[rect_cnt].bg_color.green =
nvdsosd->color_info[idx].color.green;
nvdsosd->rect_params[rect_cnt].bg_color.alpha =
nvdsosd->color_info[idx].color.alpha;
break;
#endif
rect_cnt++;
full_obj_meta_list is taken from batch_meta.
full_obj_meta_list has object_meta = (NvDsObjectMeta *) (l->data);
object_meta has rect_params
How can I add custom rectangle parameters to object_meta so that nvosd can plot?
Actually I need to draw mask. How to add to nvdsosd->mask_params?
Hi I am going to add mask params and according to _NvOSD_MaskParams Struct Reference.
float * data inside Struct represents the whole mask area in image or just contour of mask?
_NvOSD_MaskParams a;
object_meta->mask_params.push_back(a);
If push back custom maskparam to object_meta->mask_params, NvOSD can plot mask on image, right?
