**• Hardware Platform (Jetson / GPU)**Orin Nano
• DeepStream Version 6.3
**• JetPack Version (valid for Jetson only)**5.1.3
I’m trying to plot rectangle on gst-dsexample plugin.
I have segmentation fault when cv::rectangle api is applied.
When segmentation fault happened for that API?
The whole code is as follows.
static GstFlowReturn
get_converted_mat (GstDsExample * dsexample, NvBufSurface *input_buf, NvOSD_RectParams * crop_rect_params, gint idx, vector<NvOSD_RectParams> &objects, gdouble & ratio, gdouble & ratio_w, gdouble & ratio_h)
NvBufSurfTransform_Error err;
NvBufSurfTransformConfigParams transform_config_params;
NvBufSurfTransformParams transform_params;
NvBufSurfTransformRect src_rect;
NvBufSurfTransformRect dst_rect;
NvBufSurface ip_surf;
#ifdef WITH_OPENCV
cv::Mat in_mat;
#endif
ip_surf = *input_buf;
ip_surf.numFilled = ip_surf.batchSize = 1;
ip_surf.surfaceList = &(input_buf->surfaceList[idx]);
//file name
std::time_t rawtime;
std::tm* timeinfo;
char buffer [80];
std::time(&rawtime);
timeinfo = std::localtime(&rawtime);
std::strftime(buffer, 80, "%d%m%Y_%H%M_bishan_", timeinfo);
cnt++;
std::stringstream stream;
stream << cnt;
std::string str;
stream >> str;
str = str+".jpg";
strcat(buffer, str.c_str());
gint src_left = GST_ROUND_UP_2((unsigned int)crop_rect_params->left);
gint src_top = GST_ROUND_UP_2((unsigned int)crop_rect_params->top);
gint src_width = GST_ROUND_DOWN_2((unsigned int)crop_rect_params->width);
gint src_height = GST_ROUND_DOWN_2((unsigned int)crop_rect_params->height);
double hdest = dsexample->processing_width * src_height / (double) src_width;
double wdest = dsexample->processing_height * src_width / (double) src_height;
guint dest_width, dest_height;
if (hdest <= dsexample->processing_height) {
dest_width = dsexample->processing_width;
dest_height = hdest;
} else {
dest_width = wdest;
dest_height = dsexample->processing_height;
transform_config_params.compute_mode = NvBufSurfTransformCompute_Default;
transform_config_params.gpu_id = dsexample->gpu_id;
transform_config_params.cuda_stream = dsexample->cuda_stream;
err = NvBufSurfTransformSetSessionParams (&transform_config_params);
if (err != NvBufSurfTransformError_Success) {
GST_ELEMENT_ERROR (dsexample, STREAM, FAILED, ("NvBufSurfTransformSetSessionParams failed with error %d", err), (NULL));
goto error;
ratio = MIN (1.0 * dest_width/ src_width, 1.0 * dest_height / src_height);
if ((crop_rect_params->width == 0) || (crop_rect_params->height == 0)) {
GST_ELEMENT_ERROR (dsexample, STREAM, FAILED, ("%s:crop_rect_params dimensions are zero",__func__), (NULL));
goto error;
#ifdef __aarch64__
if (ratio <= 1.0 / 16 || ratio >= 16.0) {
goto error;
#endif
src_rect = {(guint)src_top, (guint)src_left, (guint)src_width, (guint)src_height};
dst_rect = {0, 0, (guint)dest_width, (guint)dest_height};
/* Set the transform parameters */
transform_params.src_rect = &src_rect;
transform_params.dst_rect = &dst_rect;
transform_params.transform_flag = NVBUFSURF_TRANSFORM_FILTER | NVBUFSURF_TRANSFORM_CROP_SRC | NVBUFSURF_TRANSFORM_CROP_DST;
transform_params.transform_filter = NvBufSurfTransformInter_Default;
/* Memset the memory */
NvBufSurfaceMemSet (dsexample->inter_buf, 0, 0, 0);
GST_DEBUG_OBJECT (dsexample, "Scaling and converting input buffer\n");
/* Transformation scaling+format conversion if any. */
err = NvBufSurfTransform (&ip_surf, dsexample->inter_buf, &transform_params);
GST_ELEMENT_ERROR (dsexample, STREAM, FAILED, ("NvBufSurfTransform failed with error %d while converting buffer", err), (NULL));
goto error;
/* Map the buffer so that it can be accessed by CPU */
if (NvBufSurfaceMap (dsexample->inter_buf, 0, 0, NVBUF_MAP_READ) != 0){
goto error;
if(dsexample->inter_buf->memType == NVBUF_MEM_SURFACE_ARRAY) {
/* Cache the mapped data for CPU access */
NvBufSurfaceSyncForCpu (dsexample->inter_buf, 0, 0);
#ifdef WITH_OPENCV
/* Use openCV to remove padding and convert RGBA to BGR. Can be skipped if
* algorithm can handle padded RGBA data. */
in_mat =
cv::Mat (dsexample->processing_height, dsexample->processing_width,
CV_8UC4, dsexample->inter_buf->surfaceList[0].mappedAddr.addr[0],
dsexample->inter_buf->surfaceList[0].pitch);
#if (CV_MAJOR_VERSION >= 4)
cv::cvtColor (in_mat, *dsexample->cvmat, cv::COLOR_RGBA2BGR);
#else
cv::cvtColor (in_mat, *dsexample->cvmat, CV_RGBA2BGR);
#endif
#endif
for(int obj_id=0; obj_id < objects.size(); obj_id++){
//gint obj_left = GST_ROUND_UP_2((unsigned int)objects[obj_id].left);
//gint obj_top = GST_ROUND_UP_2((unsigned int)objects[obj_id].top);
//gint obj_right = obj_left + GST_ROUND_DOWN_2((unsigned int)objects[obj_id].width);
//gint obj_bottom = obj_top + GST_ROUND_DOWN_2((unsigned int)objects[obj_id].height);
cv::Point p1(10, 10);
cv::Point p2(100, 100);
cv::rectangle(in_mat, p1, p2, cv::Scalar(0, 0, 255), 3, cv::LINE_8);
cv::imwrite(buffer, in_mat);
if (NvBufSurfaceUnMap (dsexample->inter_buf, 0, 0)){
goto error;
/* if(dsexample->is_integrated) {
#ifdef __aarch64__
if (USE_EGLIMAGE) {
if (NvBufSurfaceMapEglImage (dsexample->inter_buf, 0) !=0 ) {
goto error;
NvBufSurfaceUnMapEglImage (dsexample->inter_buf, 0);
#endif
return GST_FLOW_OK;
error:
return GST_FLOW_ERROR;
