Use the probe to take out the image error
• platform: orin
**• deepstream 6.1.1
**error :
VMAP_IOC_GET_FD failed: Bad address
NVMAP_IOC_GET_FD failed: Bad address
NvRmStream: Channel submission failed (err=196623)
NvRmStream: Flush failed (err=196623)
gst_nvvconv_transform: NvBufSurfTransform Failed
ERROR from element source2: Internal data stream error.
Error details: gstbasesrc.c(3072): gst_base_src_loop (): /GstPipeline:wtf-pipeline/GstBin:new-bin2/GstV4l2Src:source2:
streaming stopped, reason error (-5)
my code:
GstBuffer *buf = (GstBuffer *) info->data;
GstMapInfo in_map_info =GST_MAP_INFO_INIT;
//if(!gst_buffer_map(buf,&in_map_info,GST_MAP_READ))
//	g_print("error  map buf\n ");
	//gst_buffer_unmap(buf,&in_map_info);
//	return GST_PAD_PROBE_OK;
gst_buffer_map(buf,&in_map_info,GST_MAP_READ);
NvBufSurface * surface=(NvBufSurface *)in_map_info.data;
NvBufSurface *dst_surface=NULL;
NvBufSurfTransformRect src_rect, dst_rect;
NvBufSurfTransformParams nvbufsurface_params;
NvBufSurfaceCreateParams nvbufsurface_create_params;
cudaError_t cuda_err;
cudaStream_t cuda_stream;
gint create_result;
NvBufSurfTransformConfigParams transform_config_params;
NvBufSurfTransform_Error err;
src_rect.top = 0;
src_rect.left = 0;
src_rect.width = (guint) surface->surfaceList[batch_id].width;
src_rect.height = (guint) surface->surfaceList[batch_id].height;
dst_rect.top = 0;
dst_rect.left = 0;
dst_rect.width = (guint) surface->surfaceList[batch_id].width;
dst_rect.height = (guint) surface->surfaceList[batch_id].height;
nvbufsurface_params.src_rect = &src_rect;
nvbufsurface_params.dst_rect = &dst_rect;
nvbufsurface_params.transform_flag = NVBUFSURF_TRANSFORM_CROP_SRC | NVBUFSURF_TRANSFORM_CROP_DST;
nvbufsurface_params.transform_filter = NvBufSurfTransformInter_Default;
nvbufsurface_create_params.gpuId = surface->gpuId;
nvbufsurface_create_params.width = (guint) surface->surfaceList[batch_id].width;
nvbufsurface_create_params.height = (guint) surface->surfaceList[batch_id].height;
nvbufsurface_create_params.size = 2;
nvbufsurface_create_params.isContiguous = true;
nvbufsurface_create_params.colorFormat = NVBUF_COLOR_FORMAT_RGBA;
nvbufsurface_create_params.layout = NVBUF_LAYOUT_PITCH;
nvbufsurface_create_params.memType = 0;
create_result = NvBufSurfaceCreate(&dst_surface, batch_size, &nvbufsurface_create_params);
transform_config_params.compute_mode = NvBufSurfTransformCompute_Default;
transform_config_params.gpu_id = surface->gpuId;
transform_config_params.cuda_stream = cuda_stream;
err = NvBufSurfTransformSetSessionParams (&transform_config_params);
NvBufSurfaceMemSet (dst_surface, -1, -1, 0);
err = NvBufSurfTransform (surface, dst_surface, &nvbufsurface_params);
NvBufSurfaceMap (dst_surface, -1, -1, NVBUF_MAP_READ);
NvBufSurfaceSyncForCpu (dst_surface, -1, -1);
cv::Mat img= cv::Mat(1080,1920,CV_8UC4,dst_surface->surfaceList[0].mappedAddr.addr[0],dst_surface->surfaceList[0].pitch);
NvBufSurfaceUnMap(dst_surface,-1,-1);
NvBufSurfaceUnMap(surface,-1,-1);
g_print("---start-22---\n");
• DeepStream Version
• TensorRT Version
• The pipeline being used
ORIN
DeepStream Version:6.1.1
JetPack:5.0.2
• TensorRT Version
Tensorrt:8.4.1
Using probes to read data can cause problems。
Deepstream c++ was used to read the 4-channel camera data for splicing. I used source(v4l2)->filter(video/x-raw) convert(nvidconv)->filter(video/x-raw(memory:NVMM) 'format",(string)RGBA) to forma bin add to pipline, The overall composition is (pipines, bin1 and bin2, bin3, bin4, nvstreammux, nvmultistreamtiler, nvvidoconvert, nveglglesstransform, nveglglessink).Use the probe to read the src data of nvmultistreamtiler. Running code over a period of time can cause problems
The code for the probe is:
gint create_result;
src_rect.top = 0;
src_rect.left = 0;
dst_rect.top = 0;
dst_rect.left = 0;
g_print(“—start-22—\n”);
some questions:
  1. which deepstream sample are you developing based on?
  2. where did your add these code? can this issue be reproduced every time?
  3. can you narrow down this issue by simplifying pipeline and code?
I refer to the code for this blog ::
(118条消息) DeepStream结合OpenCV4实现视频的分析和截图(三)_deepstream 截图_MOLWH的博客-CSDN博客
if you want to capture the objects, please refer to deepstream sdk sample opt\nvidia\deepstream\deepstream-6.2\sources\apps\sample_apps\deepstream-image-meta-test\deepstream_image_meta_test.c
if you want to capture the whole frame, please refer to How to encode multiple images using the same objectMeta inside obj_meta_list - #5 by fanzh
