Hi NVIDIA Community,
I’m currently using NVDEWARPER on a Jetson Orin to create panoramic video/images from fisheye rtsp input. I am trying to set two surfaces into separate tiles, here is my example:
export GST_PLUGIN_PATH=/opt/nvidia/deepstream/deepstream-6.2/lib
gst-launch-1.0 rtspsrc location='rtsp://username:password@ipaddress:port/rtsp' ! \
rtph265depay ! \
h265parse ! \
nvv4l2decoder ! \
nvvideoconvert ! "video/x-raw(memory:NVMM),width=3000,height=3000" ! \
nvdewarper config-file=/path/to/tile.cfg ! \
m.sink_0 nvstreammux name=m width=1920 height=1080 batch-size=2 num-surfaces-per-frame=2 !\
nvmultistreamtiler columns=2 rows=1 width=1920 height=1080 ! \
nvvideoconvert ! \
nvv4l2h265enc bitrate=8000000 ! \
h265parse ! \
mux.video_0 qtmux name=mux ! \
filesink location=/dev/shm/output.mp4 -e
Here is my config file:
[property]
output-width=1920
output-height=1080
num-batch-buffers=2
[surface0]
projection-type=7
surface-index=0
width=1920
height=1080
top-angle=22.5
bottom-angle=-22.5
pitch=15.0
yaw=15.0
roll=0
src-fov=180
[surface1]
projection-type=7
surface-index=1
width=1920
height=1080
top-angle=22.5
bottom-angle=-22.5
pitch=25.0
yaw=25.0
roll=0
src-fov=180
This is the image i am getting:
As you can see, both surfaces are located in the same tile. I want to have each surface in a separate tile. How can achieve that?
