Jetson Orin Nano Developer kit-os flash in sd card -first boot shows screen for 1 min then shows blank
i am having jetson orin nano developer kit-i just flash os in sd card ,then inserted the sd card in jetson in monitor it shows nividia screen for 1 min then become blank what to do
Hi bhuvana.aug13,
It seems you are using Orin Nano rather than Jetson Nano so that I’ve moved your topic to correct category.
Could you share the full serial console log for further check?
i downloaded https://developer.nvidia.com/downloads/embedded/l4t/r36_release_v4.0/jp61-orin-nano-sd-card-image.zip for SD card image method then flash the image in sd card using balenaEtcher.then inserted the sd card in the jetson orin nano developer kit and connected the monitor with display cable then keyboard,mouse ,power cable and ethernet cable .now it just displays the above nividia screen for 1 sec
then got no display
Do you have the serial console cable?
If so, please refer to the following link to capture the log for further check.
Jetson Nano & NX Style - Serial Debug Console - JetsonHacks
