Jetson Orin Nano encoding H264 using FFMPEG on CPU
So the blog here developer.nvidia.com/blog says that:
Blockquote encoding for Jetson Orin Nano was done on CPU using ffmpeg. 110 FPS is achieved when using four CPU cores. When using two CPU cores, FPS of 73 was achieved, and when using a single CPU core, FPS of 33 was achieved
I could not achieve the frame rate mentions even use all the CPU cores of the Nano with ffmpeg, the maximum FPS I can get is about 17fps with all 6 CPU cores working at full performance
Here is the command line I used:
ffmpeg -pix_fmt yuv420p -s:v 1920x1080 -stream_loop -1 -i motion_real_video.yuv -c:v libx264 -threads 0 -f null -
Here is out put of ffmpeg -version:
ffmpeg version 4.2.7-0ubuntu0.1 Copyright (c) 2000-2022 the FFmpeg developers
built with gcc 9 (Ubuntu 9.4.0-1ubuntu1~20.04.1)
configuration: --prefix=/usr --extra-version=0ubuntu0.1 --toolchain=hardened --libdir=/usr/lib/aarch64-linux-gnu --incdir=/usr/include/aarch64-linux-gnu --arch=arm64 --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared
libavutil      56. 31.100 / 56. 31.100
libavcodec     58. 54.100 / 58. 54.100
libavformat    58. 29.100 / 58. 29.100
libavdevice    58.  8.100 / 58.  8.100
libavfilter     7. 57.100 /  7. 57.100
libavresample   4.  0.  0 /  4.  0.  0
libswscale      5.  5.100 /  5.  5.100
libswresample   3.  5.100 /  3.  5.100
libpostproc    55.  5.100 / 55.  5.100
Here is the YUV file I used for encoding, if anyone wants to give it a try…
motion_real_video.yuv (83.1 MB)
Am I missing something?
Please use h264 stream in 1080p as input and try the command:
$ sudo jetson_clocks
$ gst-launch-1.0 multifilesrc location=h264_1080p.264 loop=1 ! h264parse ! nvv4l2decoder enable-max-performance=1 ! 'video/x-raw(memory:NVMM)' ! nvvidconv ! 'video/x-raw' ! x264enc speed-preset="ultrafast" ! 'video/x-h264' ! fpsdisplaysink text-overlay=0 video-sink=fakesink sync=0 -v
And you can run sudo tegrastats to make sure 2 CPU cores or 4 cores are online.
The pipeline does not work, since fpsdisplaysink does not accept h264 input
So a re-run without fpsdisplay using this pipeline
gst-launch-1.0 multifilesrc location=h264_video.264 loop=1 ! h264parse ! nvv4l2decoder enable-max-performance=1 ! 'video/x-raw(memory:NVMM)' ! nvvidconv ! 'video/x-raw' ! x264enc speed-preset="ultrafast" ! 'video/x-h264' ! fakesink sync=0 -v
This is the output:
Setting pipeline to PAUSED ...
Opening in BLOCKING MODE
Pipeline is PREROLLING ...
/GstPipeline:pipeline0/GstH264Parse:h264parse0.GstPad:src: caps = video/x-h264, pixel-aspect-ratio=(fraction)1/1, width=(int)1440, height=(int)1080, framerate=(fraction)25/1, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true, stream-format=(string)byte-stream, alignment=(string)au, profile=(string)high, level=(string)4
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
/GstPipeline:pipeline0/nvv4l2decoder:nvv4l2decoder0.GstPad:sink: caps = video/x-h264, pixel-aspect-ratio=(fraction)1/1, width=(int)1440, height=(int)1080, framerate=(fraction)25/1, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true, stream-format=(string)byte-stream, alignment=(string)au, profile=(string)high, level=(string)4
/GstPipeline:pipeline0/nvv4l2decoder:nvv4l2decoder0.GstPad:src: caps = video/x-raw(memory:NVMM), format=(string)NV12, width=(int)1440, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)25/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw(memory:NVMM), format=(string)NV12, width=(int)1440, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)25/1
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:src: caps = video/x-raw, width=(int)1440, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)25/1, format=(string)NV12
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:src: caps = video/x-raw, width=(int)1440, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)25/1, format=(string)NV12
Redistribute latency...
/GstPipeline:pipeline0/GstX264Enc:x264enc0.GstPad:sink: caps = video/x-raw, width=(int)1440, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)25/1, format=(string)NV12
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:sink: caps = video/x-raw, width=(int)1440, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)25/1, format=(string)NV12
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:sink: caps = video/x-raw(memory:NVMM), format=(string)NV12, width=(int)1440, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)25/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw(memory:NVMM), format=(string)NV12, width=(int)1440, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)25/1
/GstPipeline:pipeline0/GstX264Enc:x264enc0.GstPad:src: caps = video/x-h264, codec_data=(buffer)0142c028ffe1001c6742c028da0168089f97016a020202800000030080000019478c195001000468ce3c80, stream-format=(string)avc, alignment=(string)au, level=(string)4, profile=(string)constrained-baseline, width=(int)1440, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)25/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, chroma-site=(string)mpeg2, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono
/GstPipeline:pipeline0/GstCapsFilter:capsfilter2.GstPad:src: caps = video/x-h264, codec_data=(buffer)0142c028ffe1001c6742c028da0168089f97016a020202800000030080000019478c195001000468ce3c80, stream-format=(string)avc, alignment=(string)au, level=(string)4, profile=(string)constrained-baseline, width=(int)1440, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)25/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, chroma-site=(string)mpeg2, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono
/GstPipeline:pipeline0/GstFakeSink:fakesink0.GstPad:sink: caps = video/x-h264, codec_data=(buffer)0142c028ffe1001c6742c028da0168089f97016a020202800000030080000019478c195001000468ce3c80, stream-format=(string)avc, alignment=(string)au, level=(string)4, profile=(string)constrained-baseline, width=(int)1440, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)25/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, chroma-site=(string)mpeg2, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono
/GstPipeline:pipeline0/GstCapsFilter:capsfilter2.GstPad:sink: caps = video/x-h264, codec_data=(buffer)0142c028ffe1001c6742c028da0168089f97016a020202800000030080000019478c195001000468ce3c80, stream-format=(string)avc, alignment=(string)au, level=(string)4, profile=(string)constrained-baseline, width=(int)1440, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)25/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, chroma-site=(string)mpeg2, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
tegrastats
02-21-2023 05:06:26 RAM 1961/3723MB (lfb 4x1MB) SWAP 134/1861MB (cached 1MB) CPU [57%@1510,56%@1510,58%@1510,56%@1510,39%@1510,34%@1510] EMC_FREQ 0% GR3D_FREQ 0% GR3D2_FREQ 0%@0 CV0@-256C CPU@48.656C Tboard@36C SOC2@44.625C Tdiode@36.75C SOC0@44.218C CV1@-256C GPU@42.406C tj@48.656C SOC1@44.156C CV2@-256C
Where can I read the fps of encoding ?
The command was not correct and have made correction. Please try again. It would be:
... ! fpsdisplaysink text-overlay=0 video-sink=fakesink sync=0 -v
Ok, so this command:
gst-launch-1.0 multifilesrc location=h264_2K_30fps.264 loop=1 ! h264parse ! nvv4l2decoder enable-max-performance=1 ! 'video/x-raw(memory:NVMM)' ! nvvidconv ! 'video/x-raw' ! x264enc speed-preset="ultrafast" ! 'video/x-h264' ! fpsdisplaysink text-overlay=0 video-sink=fakesink sync=0 -v
gave me this output
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstFakeSink:fakesink0: sync = false
/GstPipeline:pipeline0/GstH264Parse:h264parse0.GstPad:src: caps = video/x-h264, pixel-aspect-ratio=(fraction)3/4, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true, stream-format=(string)byte-stream, alignment=(string)au, profile=(string)high, level=(string)4
/GstPipeline:pipeline0/nvv4l2decoder:nvv4l2decoder0.GstPad:sink: caps = video/x-h264, pixel-aspect-ratio=(fraction)3/4, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true, stream-format=(string)byte-stream, alignment=(string)au, profile=(string)high, level=(string)4
/GstPipeline:pipeline0/nvv4l2decoder:nvv4l2decoder0.GstPad:src: caps = video/x-raw(memory:NVMM), format=(string)NV12, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)3/4, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw(memory:NVMM), format=(string)NV12, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)3/4, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)30/1
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:src: caps = video/x-raw, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)3/4, framerate=(fraction)30/1, format=(string)NV12
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:src: caps = video/x-raw, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)3/4, framerate=(fraction)30/1, format=(string)NV12
/GstPipeline:pipeline0/GstX264Enc:x264enc0.GstPad:sink: caps = video/x-raw, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)3/4, framerate=(fraction)30/1, format=(string)NV12
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:sink: caps = video/x-raw, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)3/4, framerate=(fraction)30/1, format=(string)NV12
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:sink: caps = video/x-raw(memory:NVMM), format=(string)NV12, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)3/4, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw(memory:NVMM), format=(string)NV12, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)3/4, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstX264Enc:x264enc0.GstPad:src: caps = video/x-h264, codec_data=(buffer)0142c028ffe100206742c028da01e0089f97ff000300046a02020280000003008000001e478c195001000468ce3c80, stream-format=(string)avc, alignment=(string)au, level=(string)4, profile=(string)constrained-baseline, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)3/4, framerate=(fraction)30/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, chroma-site=(string)mpeg2, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono
/GstPipeline:pipeline0/GstCapsFilter:capsfilter2.GstPad:src: caps = video/x-h264, codec_data=(buffer)0142c028ffe100206742c028da01e0089f97ff000300046a02020280000003008000001e478c195001000468ce3c80, stream-format=(string)avc, alignment=(string)au, level=(string)4, profile=(string)constrained-baseline, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)3/4, framerate=(fraction)30/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, chroma-site=(string)mpeg2, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0.GstGhostPad:sink.GstProxyPad:proxypad0: caps = video/x-h264, codec_data=(buffer)0142c028ffe100206742c028da01e0089f97ff000300046a02020280000003008000001e478c195001000468ce3c80, stream-format=(string)avc, alignment=(string)au, level=(string)4, profile=(string)constrained-baseline, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)3/4, framerate=(fraction)30/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, chroma-site=(string)mpeg2, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstFakeSink:fakesink0.GstPad:sink: caps = video/x-h264, codec_data=(buffer)0142c028ffe100206742c028da01e0089f97ff000300046a02020280000003008000001e478c195001000468ce3c80, stream-format=(string)avc, alignment=(string)au, level=(string)4, profile=(string)constrained-baseline, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)3/4, framerate=(fraction)30/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, chroma-site=(string)mpeg2, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0.GstGhostPad:sink: caps = video/x-h264, codec_data=(buffer)0142c028ffe100206742c028da01e0089f97ff000300046a02020280000003008000001e478c195001000468ce3c80, stream-format=(string)avc, alignment=(string)au, level=(string)4, profile=(string)constrained-baseline, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)3/4, framerate=(fraction)30/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, chroma-site=(string)mpeg2, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono
/GstPipeline:pipeline0/GstCapsFilter:capsfilter2.GstPad:sink: caps = video/x-h264, codec_data=(buffer)0142c028ffe100206742c028da01e0089f97ff000300046a02020280000003008000001e478c195001000468ce3c80, stream-format=(string)avc, alignment=(string)au, level=(string)4, profile=(string)constrained-baseline, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)3/4, framerate=(fraction)30/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, chroma-site=(string)mpeg2, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 52, dropped: 0, current: 103.07, average: 103.07
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 103, dropped: 0, current: 100.84, average: 101.95
And tegrastats reports this
02-21-2023 06:00:08 RAM 1630/3723MB (lfb 31x512kB) SWAP 616/1861MB (cached 1MB) CPU [57%@1510,52%@1510,49%@1510,52%@1510,42%@1510,52%@1510] EMC_FREQ 0% GR3D_FREQ 0% GR3D2_FREQ 0%@0 CV0@-256C CPU@50.312C Tboard@37C SOC2@45.843C Tdiode@38C SOC0@45.562C CV1@-256C GPU@43.656C tj@50.312C SOC1@45.343C CV2@-256C
If I understand correctly, the gstreamer pipeline ran at ~100fps, with the cost of CPU usage on average of 6 cores was about ~50%, is it correct?
So this option change the encoder parameter to be the “ultrafast” for the trade-off between speed and image quality. I have played around with the medium and found the encoder speed could achieve ~20fps, with the cost of ~63% on average of 6 CPU cores:
02-21-2023 07:53:10 RAM 2124/3723MB (lfb 1x2MB) SWAP 827/1861MB (cached 1MB) CPU [67%@1510,48%@1510,43%@1510,100%@1510,66%@1510,59%@1510] EMC_FREQ 0% GR3D_FREQ 0% GR3D2_FREQ 0%@0 CV0@-256C CPU@49.656C Tboard@36C SOC2@45.281C Tdiode@37.25C SOC0@44.812C CV1@-256C GPU@42.906C tj@49.656C SOC1@44.781C CV2@-256C
However, the quality of image still not suitable for the use of my application.
Is there anything else I can try?
There are other properties in x264enc plugin: x264enc
Please check and try to configure the properties. This would also need other users to share experience.
For using hardware encoder, we will suggest set to CBR mode and set virtual buffer size like:
Random blockiness in the picture RTSP server-client -Jetson TX2 - #5 by DaneLLL
Would need other users to share how to configure the same in x264enc
