we are using several NVIDIA Jetson Orin Nano systems with NVMe SSDs running JetPack 7.2. We are experiencing recurring filesystem corruption, sometimes leaving the system unable to boot.
The following errors appear during boot:
JBD2: Invalid checksum recovering data block
JBD2: journal recovery failed
EXT4-fs (nvme0n1p1): error loading journal
mount: /mnt: cannot mount: probably corrupted filesystem on /dev/nvme0n1p1
nvme nvme0: I/O tag timeout
This has happened more than once, so it does not appear to be an isolated corrupted image.
We also performed a cross-test with another working Jetson Orin Nano:
- An NVMe SSD that boots correctly in another Jetson does not boot in the affected Jetson.
- On the affected Jetson, it reaches “Attempting recovery boot” and then gets stuck.
- The same SSD works correctly when moved back to the other Jetson.
This makes us suspect that the issue may not be caused by the NVMe SSD itself, but possibly by the Jetson hardware, firmware/UEFI, QSPI bootloader, or the NVMe/PCIe interface.
Has anyone experienced similar recurring EXT4/NVMe corruption on Jetson Orin Nano with JetPack 7.2?
Is there any good way to debug such errors or get to related debug files on the disk?
