The Jetson Orin Nano initially booted successfully from a microSD card containing a JetPack image. Then I tried to improve performance by moving the root filesystem from the microSD card to an NVMe SSD.
- Installed an NVMe SSD in the Jetson.
- Partitioned and formatted the NVMe drive.
- Mounted the NVMe under:
/mnt/nvme
- Copied the existing root filesystem from the microSD card to the NVMe using
rsync.
sudo rsync -aAXv --info=progress2 / /mnt/nvme
–exclude={“/dev/“,”/proc/”,“/sys/“,”/tmp/”,“/run/“,”/mnt/”,“/media/*”,“/lost+found”}
Files Modified
1. /etc/fstab
Replacing the root mount entry with the UUID of the NVMe.
Keeping
/boot/efipointing to the SD card EFI partition.
UUID=<NVME_UUID> / ext4 defaults 0 1
UUID=<SD_EFI_UUID> /boot/efi vfat defaults 0 1
2. /boot/extlinux/extlinux.conf
root=/dev/mmcblk0p1 Changed to: root=/dev/nvme0n1p1 rw rootwait
This was the last major configuration file modified before the system stopped booting correctly.
Problems Encountered After modifying extlinux.conf:
- The Jetson entered Emergency Mode during boot.
- Errors related to: Failed to mount /boot/efi
Later:
- The system stopped booting entirely from the SD card.
- Even after removing the NVMe SSD, the Jetson still failed to boot normally.
Recovery / Troubleshooting Attempts
- UEFI / Boot Menu Actions Entered the UEFI menu using
ESCandF11. The following actions were attempted: Boot Manager Verified that: - UEFI SD Device - Boot Maintenance Manager Performed: F9 → Reset to Defaults and then: F10 → Save
- NVIDIA Configuration Menu Entered: Device Manager → NVIDIA Configuration and again performed: F9 → Reset to Defaults F10 → Save
- Boot From File Attempted manual boot from: EFI/BOOT/BOOTAA64.efi
- Result: Returned to black screen / failed boot.
SD Card Reflash Attempt To rule out SD corruption:
- Reflashed the microSD card with the same JetPack image that had previously worked.
- Used balenaEtcher for flashing.
- Verified that Windows detected multiple Linux partitions afterward (expected behavior).
- Reinserted the reflashed SD card into the Jetson.
Result: System still failed to boot normally.
Current Status
- Jetson reaches UEFI / Boot Manager successfully.
- SD card is detected correctly.
- Boot process begins but does not complete.
- Often falls into recovery attempts or black screen.
- System no longer boots into Linux successfully.
Please advice what can I do, currently I dont have Linux PC for recovery
Best regards,
Ilan
