I think i bricked the orin Nano super by switching to nvme as boot
I initially followed the steps to boot the latest firmware on the ssd. Then i installed an nvme and it worked. I then tried to change the boot to basically boot from the nvme only. Once i copied the contents, it did not work. I’m not even getting a valid display anymore. Even if i removed the nvme, and placed the latest ssd, it still doesnt recognize anything. What are my options.
Use the flash script and the jumper.
You won’t really ruin anything on Jetson platform just because you accidentally installed something wrong.
The worst case is put your Jetson into recovery mode (by a jumper) and use another x86 host PC to reflash it by usb connection.
