I am working with a Jetson Orin Nano developer kit and have completed my project. My OS is currently configured, with all the necessary packages and OS settings. How can I copy my OS from the micro SD card it is currently on to a NVMe SSD, and how can I configure the Orin to boot from SSD instead?
Check this:
https://docs.nvidia.com/jetson/archives/r36.2/DeveloperGuide/SD/FlashingSupport.html#cloning-rootfs-with-initrd
Then flash the SSD and use dd to write the cloned image back to the partition on the SSD.
You also need to change root=/dev/mmcblk0p1 in /boot/extlinux/extlinux.conf to root=/dev/nvme0n1p1.
You can refer to this github repo for your use case.
