Hi We used below command to flash jetson Orin NX 16GB module and also Orin Nano module. However it gets failed while flashing (external NVMe)if we use it for Orin NX 8GB. is there any change we have to make in the flash command?
**sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c**
tools/kernel_flash/flash_l4t_external.xml -p “-c bootloader/t186ref/cfg/flash_t234_qspi.xml” --showlogs
–network usb0 jetson-orin-nano-devkit internal
see below flash log:
flashlog-jetson_orin_nx.txt (285.0 KB)
