Orin nx can not flash jetpack 6.0
I try to flash the module with the following command:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_
t234_nvme.xml -p “-c bootloader/generic/cfg/flash_t234_qspi.xml” --showlogs --network usb0 jetson-orin-nano-devkit-nvme internal
I also try :
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_t234_nvme.xml -p “-c bootloader/generic/cfg/flash_t234_qspi.xml” --showlogs --network usb0 p3509-a02-p3767-0000 internal
All command will put the error:
Flash failure
Either the device cannot mount the NFS server on the host or a flash command has failed. Debug lo
g saved to /tmp/tmp.nEkHLjjERv. You can access the target’s terminal through “sshpass -p root ssh
root@fc00:1:1:0::2”
Cleaning up…
Hi nxsf8023,
Are you using the devkit or custom board for Orin NX?
Are you trying to flash into NVMe SSD?
Please share the full flash log for further check.
