Hello!
I’ve been struggling to get CAN working on my Orin NX. I’ve found that transmit only works when I enable CAN loopback mode, and I have not been able to get CAN receive to work at all. I’ve seen that a few other folks have reported similar issues, but that the threads ended without any real resolution (thread1, thread2).
Hardware Setup
I’m using a Jetson Orin NX Dev Kit with a CAN transceiver hooked up to the J17 header. I’m using the recommended Waveshare transceiver board, and have verified that it is wired correctly.
For a link partner, I’m using a Peak Systems PCAN-USB. I’ve verified that the CAN bus is properly terminated with 120Ω on each end (measured 60Ω between CAN_H/CAN_L). and verified that the PCAN-USB can send messages onto the bus as expected (although they are not ACK’d by the Jetson).
Here’s what I see on the oscilloscope (probing channel1=CAN_H, channel2=CAN_L, probed at the header on the Jetson’s CAN transceiver board):
As you can see, the bus signal integrity looks great, and the CAN packet is properly formed, although not being ACK’d by the Jetson.
Software Setup
The Jetson has been freshly flashed from SDKManager. I’ve tried various Jetpack versions to see if that made any difference (I didn’t have any luck with any of them), but the results reported here are with a fresh flash with Jetpack 5.1.1.
Here’s the report in JetsonHacks jtop:
I followed the directions in the Developer Guide for setting up CAN:
jetson@ubuntu:~$ sudo busybox devmem 0xc303018 w 0xc458
jetson@ubuntu:~$ sudo busybox devmem 0xc303010 w 0xc400
jetson@ubuntu:~$ sudo modprobe can
jetson@ubuntu:~$ sudo modprobe can_raw
jetson@ubuntu:~$ sudo modprobe mttcan
jetson@ubuntu:~$ sudo ip link set can0 up type can bitrate 500000 dbitrate 1000000 berr-reporting on fd on
jetson@ubuntu:~$ ip -d link show can0
9: can0: <NOARP,UP,LOWER_UP,ECHO> mtu 72 qdisc pfifo_fast state UP mode DEFAULT
group default qlen 10
link/can promiscuity 0 minmtu 0 maxmtu 0
can <BERR-REPORTING,FD> state ERROR-ACTIVE (berr-counter tx 0 rx 0) restart-ms 0
bitrate 500000 sample-point 0.870
tq 20 prop-seg 43 phase-seg1 43 phase-seg2 13 sjw 1
mttcan: tseg1 2..255 tseg2 0..127 sjw 1..127 brp 1..511 brp-inc 1
dbitrate 1000000 dsample-point 0.720
dtq 40 dprop-seg 8 dphase-seg1 9 dphase-seg2 7 dsjw 1
mttcan: dtseg1 1..31 dtseg2 0..15 dsjw 1..15 dbrp 1..15 dbrp-inc 1
clock 50000000 numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535
jetson@ubuntu:~$ candump -x any &
[1] 3812
FAILURE - Non-loopback Packet Transmission
At this point, if I send a packet with cansend can0 123#abcdabcd, the following occurs:
- The link partner (PCAN-USB) does not report receiving the packet
candumpdoes not report a transmitted packet- On the oscilloscope (same probing setup as above), I see some confusing activity but not a valid packet transmission:
Here’s another scope capture from a different run zoomed out:
If I then try to run cansend again, I get no activity on the bus.
The system reports state: BUS-OFF and I see some bit errors in dmesg:
9: can0: <NO-CARRIER,NOARP,UP,ECHO> mtu 72 qdisc pfifo_fast state DOWN mode DEFAULT group default qlen 10
can <BERR-REPORTING,FD> state BUS-OFF (berr-counter tx 248 rx 0) restart-ms 0
jetson@ubuntu:~$ sudo dmesg | tail
[ 539.644100] mttcan_controller_config: ctrlmode 30
[ 539.644121] mttcan c310000.mttcan can0: Bitrate set
[ 539.644231] IPv6: ADDRCONF(NETDEV_CHANGE): can0: link becomes ready
[ 969.014314] mttcan c310000.mttcan can0: Bit0 Error Detected
[ 969.020081] mttcan c310000.mttcan can0: IR 0x8010000 PSR 0x71d
[ 969.026178] mttcan c310000.mttcan can0: entered error warning state
[ 969.032686] mttcan c310000.mttcan can0: entered error passive state
[ 969.039183] mttcan c310000.mttcan can0: entered bus off state
[ 969.045118] mttcan c310000.mttcan can0: Bit0 Error Detected
[ 969.050895] mttcan c310000.mttcan can0: IR 0xb800000 PSR 0x7e5
This state seems unrecoverable. I’ve tried setting the link down and then back up again to get out of the BUS-OFF state (which appears to succeed), but I never see any more activity on the bus with further can-send commands.
jetson@ubuntu:~$ sudo ip link set can0 down
9: can0: <NOARP,UP,LOWER_UP,ECHO> mtu 72 qdisc pfifo_fast state UP mode DEFAULT group default qlen 10
jetson@ubuntu:~$ cansend can0 123#abcdabcd
[ 1556.229103] mttcan_controller_config: ctrlmode 30
[ 1556.229131] mttcan c310000.mttcan can0: Bitrate set
[ 1556.229140] mttcan c310000.mttcan can0: wait for bus off seq
[ 1556.241226] mttcan c310000.mttcan can0: Bit0 Error Detected
[ 1556.241268] IPv6: ADDRCONF(NETDEV_CHANGE): can0: link becomes ready
[ 1556.246995] mttcan c310000.mttcan can0: IR 0xa000000 PSR 0x70d
I’ve only been able to get the bus to show activity (the same incorrect activity in the scope shot above, but activity nonetheless) after a system reboot.
SUCCESS? - Loopback Packet Transmission
After a ton of trial and error, I found that I could get packets to reliably transmit correctly if I enable loopback on the CAN peripheral. With all the other settings and steps from above unchanged, if I do:
jetson@ubuntu:~$ sudo ip link set can0 up type can bitrate 500000 dbitrate 1000000 berr-reporting on fd on loopback on
can <LOOPBACK,BERR-REPORTING,FD> state ERROR-ACTIVE (berr-counter tx 0 rx 0) restart-ms 0
[1] 3042
jetson@ubuntu:~$ can0 RX - - 123 [4] AB CD AB CD
can0 TX - - 123 [4] AB CD AB CD
I see the CAN packet transmitted correctly to the bus and reported by candump. Here’s a scope shot:
And the link partner (PCAN-USB) correctly receives the CAN packet as well. I can continue sending packets, and they are correctly sent to the bus. However, as you’d expect I cannot receive any packets on the Jetson due to loopback being enabled.
Questions
- Can someone help me debug why messages are not transmitted correctly unless loopback mode is on?
- Is there a way to recover from BUS-OFF without rebooting the system?
