Jetson Orin Software Inventory
Is there a listing of the Operating System and version for the Jetson Orin available and any of its supported packages? I’m also specifically interested in whether Qt is supported and if so, what version? We are looking to transition from Jetson TX2 to Orin and needing to assess the feasibility.
Hi @jim.pedavoli, Jetson AGX Orin supports JetPack 5.0 which currently runs Ubuntu 20.04. So it includes the apt packages that you would get from Ubuntu 20.04 (focal): https://packages.ubuntu.com/
It appears that this includes Qt5:
$ apt-cache search libqt
dde-qt5integration - Qt5 theme integration for Deepin application
libqscintilla2-qt5-dev - Scintilla source code editing widget for Qt5, development files
libqt5-ukui-style-dev - Development files of libqt5-ukui-style1
libqt5-ukui-style1 - UKUI platform theme and styles' shared library
libqt53danimation5 - Qt 3D animation module
libqt53dcore5 - Qt 3D module
libqt53dextras5 - Qt 3D extras
libqt53dinput5 - Qt 3D Input module
libqt53dlogic5 - Qt 3D logic module
libqt53dquick5 - Qt 3D Quick module
libqt53dquickanimation5 - Qt 3D Quick animation module
libqt53dquickextras5 - Qt 3D Quick extras
libqt53dquickinput5 - Qt 3D Quick input
libqt53dquickrender5 - Qt 3D Quick Renderer module
libqt53dquickscene2d5 - Qt 3D Quick scene module
libqt53drender5 - Qt 3D Renderer module
libqt5bluetooth5 - Qt Connectivity Bluetooth module
libqt5bluetooth5-bin - Qt Connectivity Bluetooth module helper binaries
libqt5charts5 - Qt charts shared library
libqt5charts5-dev - Qt charts development files
libqt5concurrent5 - Qt 5 concurrent module
libqt5core5a - Qt 5 core module
libqt5datavisualization5 - Qt 5 Data Visualization module
libqt5datavisualization5-dev - APIs for data visualization functionality - development files
libqt5dbus5 - Qt 5 D-Bus module
libqt5designer5 - Qt 5 designer module
libqt5designercomponents5 - Qt 5 Designer components module
libqt5gamepad5 - Qt 5 gamepad module
libqt5gamepad5-dev - Qt 5 gamepad module - development files
libqt5glib-2.0-0 - C++ bindings library for GLib and GObject with a Qt-style API - Qt 5 build
libqt5gstreamer-1.0-0 - C++ bindings library for GStreamer with a Qt-style API - Qt 5 build
libqt5gstreamer-dev - Development headers for QtGStreamer - Qt 5 build
libqt5gstreamerquick-1.0-0 - QtGStreamerQuick library - Qt 5 build
libqt5gstreamerui-1.0-0 - QtGStreamerUi library - Qt 5 build
libqt5gstreamerutils-1.0-0 - QtGStreamerUtils library - Qt 5 build
libqt5gui5 - Qt 5 GUI module
libqt5gui5-gles - Qt 5 GUI module — OpenGL ES variant
libqt5help5 - Qt 5 help module
libqt5hunspellinputmethod5 - Qt virtual keyboard - helper library for Hunspell input method
libqt5keychain1 - Qt API to store passwords (QT5 version)
libqt5location5 - Qt Location module
libqt5location5-plugin-mapboxgl - Qt Location module - Mapbox GL plugin
libqt5location5-plugins - Qt Location module - geolocation plugins
libqt5multimedia5 - Qt 5 Multimedia module
libqt5multimedia5-plugins - Qt 5 Multimedia module plugins
libqt5multimediagsttools5 - GStreamer tools for  Qt 5 Multimedia module
libqt5multimediaquick5 - Qt 5 Multimedia Quick module
libqt5multimediawidgets5 - Qt 5 Multimedia Widgets module
libqt5network5 - Qt 5 network module
libqt5networkauth5 - online account access for Qt apps - Library
libqt5networkauth5-dev - online account access for Qt apps - Development Files
libqt5nfc5 - Qt Connectivity NFC module
libqt5opengl5 - Qt 5 OpenGL module
libqt5opengl5-dev - Qt 5 OpenGL library development files
libqt5pas-dev - Development files for Qt5Pas
libqt5pas1 - Qt5 interface bindings for Pascal
libqt5positioning5 - Qt Positioning module
libqt5positioning5-plugins - Qt Positioning module - position plugins
libqt5positioningquick5 - Qt Positioning module - Qt Quick module
libqt5printsupport5 - Qt 5 print support module
libqt5qevercloud3 - Unofficial Evernote Cloud API library for Qt5
libqt5qml5 - Qt 5 QML module
libqt5quick5 - Qt 5 Quick library
libqt5quick5-gles - Qt 5 Quick library — OpenGL ES variant
libqt5quickcontrols2-5 - Qt 5 Quick Controls 2 library
libqt5quickparticles5 - Qt 5 Quick particles module
libqt5quickparticles5-gles - Qt 5 Quick particles module — OpenGL ES variant
libqt5quickshapes5 - Qt 5 Quick Shapes module
libqt5quicktemplates2-5 - Qt 5 Quick Templates 2 library
libqt5quicktest5 - Qt 5 Quick Test library
libqt5quickwidgets5 - Qt 5 Quick Widgets library
libqt5remoteobjects5 - Qt module for IPC
libqt5remoteobjects5-bin - Qt module for IPC — the Replica Compiler (repc)
libqt5remoteobjects5-dev - Qt module for IPC — development files
libqt5scintilla2-designer - Qt5 Designer plugin for QScintilla 2 (Transitional package)
libqt5script5 - Qt 5 script module
libqt5scripttools5 - Qt 5 script tools module
libqt5scxml5 - Qt module for creating state machines from SCXML files library
libqt5scxml5-bin - Qt module for creating state machines from SCXML files helper
libqt5scxml5-dev - Qt module for creating state machines from SCXML files development
libqt5sensors5 - Qt Sensors module
libqt5sensors5-dev - Qt 5 Sensors development files
libqt5serialbus5 - Qt serialbus - serial bus access shared library
libqt5serialbus5-bin - Qt Serialbus module serial bus access helper binaries
libqt5serialbus5-dev - Qt serialbus serial bus access development
libqt5serialbus5-plugins - Qt serialbus - serial bus access plugins
libqt5serialport5 - Qt 5 serial port support
libqt5serialport5-dev - Qt 5 serial port development files
libqt5sql5 - Qt 5 SQL module
libqt5sql5-ibase - Qt 5 Firebird database driver
libqt5sql5-mysql - Qt 5 MySQL database driver
libqt5sql5-odbc - Qt 5 ODBC database driver
libqt5sql5-psql - Qt 5 PostgreSQL database driver
libqt5sql5-sqlite - Qt 5 SQLite 3 database driver
libqt5sql5-tds - Qt 5 FreeTDS database driver
libqt5svg5 - Qt 5 SVG module
libqt5svg5-dev - Qt 5 SVG module development files
libqt5test5 - Qt 5 test module
libqt5texttospeech5 - Speech library for Qt - libraries
libqt5texttospeech5-dev - Speech library for Qt - development files
libqt5virtualkeyboard5 - Qt virtual keyboard - public shared library
libqt5virtualkeyboard5-dev - Qt virtual keyboard - development files
libqt5waylandclient5 - QtWayland client library
libqt5waylandclient5-dev - QtWayland client development files
libqt5waylandcompositor5 - QtWayland compositor library
libqt5waylandcompositor5-dev - QtWayland compositor development files
libqt5webchannel5 - Web communication library for Qt
libqt5webchannel5-dev - Web communication library for Qt - development files
libqt5webengine-data - Web content engine library for Qt - Data
libqt5webengine5 - Web content engine library for Qt
libqt5webenginecore5 - Web content engine library for Qt - Core
libqt5webenginewidgets5 - Web content engine library for Qt - Widget
libqt5webkit5 - Web content engine library for Qt
libqt5webkit5-dev - Web content engine library for Qt - development files
libqt5websockets5 - Qt 5 Web Sockets module
libqt5websockets5-dev - Qt 5 Web Sockets module - development files
libqt5webview5 - display web content in a QML application - Library
libqt5webview5-dev - display web content in a QML application - Development Files
libqt5widgets5 - Qt 5 widgets module
libqt5x11extras5 - Qt 5 X11 extras
libqt5x11extras5-dev - Qt 5 X11 extras development files
libqt5xdg-dev - Development files for libqtxdg
libqt5xdg3 - Implementation of the XDG Specifications for Qt (shared lib)
libqt5xdgiconloader-dev - Development files for libqtxdgiconloader
libqt5xdgiconloader3 - Implementation of the XDG Iconloader for Qt (shared lib)
libqt5xml5 - Qt 5 XML module
libqt5xmlpatterns5 - Qt 5 XML patterns module
libqt5xmlpatterns5-dev - Qt 5 XML patterns development files
libqtav-dev - QtAV development files
libqtav-private-dev - QtAV private development files
libqtav1 - QtAV library
libqtavwidgets1 - QtAV Widgets module
libqtcurve-utils2 - common library for QtCurve
libqtdbusmock1 - Library for mocking DBus interactions using Qt
libqtdbusmock1-common - Library for mocking DBus interactions using Qt (common files)
libqtdbusmock1-dev - Library for mocking DBus interactions using Qt (development files)
libqtdbustest1 - Library for testing DBus interactions using Qt
libqtdbustest1-dev - Library for testing DBus interactions using Qt (development files)
libqtermwidget5-0 - Terminal emulator widget for Qt 5 (shared libraries)
libqtermwidget5-0-dev - Terminal emulator widget for Qt 5 (development files)
libqtest-ocaml - Inline (Unit) Tests for OCaml (Runtime library)
libqtest-ocaml-dev - Inline (Unit) Tests for OCaml (Development package)
libqtest-ocaml-doc - Documentation for ocaml-qtest
libqtspell-qt5-0 - Spell checking for Qt5 text widgets library
libqtspell-qt5-dev - Development files for libqtspell-qt5
libqtspell-qt5-html - Spell checking for Qt5 text widgets documentation
qt5dxcb-plugin - Qt platform theme integration plugin for DDE
qt5qevercloud-dev - Development files for libqt5qevercloud
qtdbustest-runner - Library for testing DBus interactions using Qt (test runner executable)
